It is currently Sun Jul 13, 2025 3:36 am
 Post subject: Making of Nemo1
PostPosted: Thu May 21, 2020 4:40 pm
First name: Brad
Last Name: Combs
Hello,
I posted this in the ukulele forum where I’ve been posting pics in a build thread, but I thought I would share here too because it could be useful for any small bodied instrument, not just ukulele.
I press frets using a Jaws2 and a Nemo1. The Nemo1 was born out of this thread from our friend Dave Farmer.
fixing Jaws 2
https://r.tapatalk.com/shareLink/topic? ... source=app
He’s not around on the OLF as much anymore but there are a ton of gems in his previous posts. :)
If the big guy is Jaws2 then this has to be Nemo1. SM should sell this and give me royalties.
As I mentioned this idea came from a post where David Farmer replaced the knock off Bessey clamp on the Jaws2 with a real one. Making the press screw into something compatible with the SM clamping caul is pretty straight forward. What I’m doing here is making a second clamp from the smallest Bessey clamp. This let’s me fret the last few frets in a small sound hole like a uke.
First I have to remove the pin in the handle. I filed the pin head flat so that I can drill it out easier on the drill press. I used some scraps to try to square it up.
Pop the cap off with pliers.
I used an 1/8” dowel to encourage the pin out with a hammer.
Pull out the press screw with pliers.
This is what we are trying to replicate. The pin is 6.25mm with a slot cut that is 4.5mm. The slot is where the plastic set screw goes on the SM caul.
Drilled a hole in the waste board so I can sink the press screw down and cut the slot using the files edge.
Cut off the tip that was originally there with a hacksaw and file it flat in the drill press.
Looks good.
I used steel pop rivets to put the handle back on.
I also trim the nose off just a bit so that it can get closer to the neck block. This helps with getting to reach as many frets as possible. I learned about the stubby Jaws2 from Dave and Hesh in their fretting class. :)
I use a cut down version of the SM clamping caul so it can go in and out of the smaller sound hole.
It’s a little fiddly to get it all set up through the sound hole but once set up it works great!
Hope that is useful.
Brad
 Post subject: Re: Making of Nemo1
PostPosted: Fri May 22, 2020 7:00 am
Looks "factory" Great job!
These users thanked the author Clay S. for the post: bcombs510 (Fri May 22, 2020 11:34 am)
PostPosted: Fri May 22, 2020 9:25 am
Indeed! Very nice.
These users thanked the author jfmckenna for the post: bcombs510 (Fri May 22, 2020 11:34 am)
PostPosted: Fri May 22, 2020 9:58 am
Nicely done Brad.
These users thanked the author SteveSmith for the post: bcombs510 (Fri May 22, 2020 11:34 am)
PostPosted: Fri May 22, 2020 12:58 pm
I like it, WTG Brad!
These users thanked the author Pmaj7 for the post: bcombs510 (Fri May 22, 2020 1:35 pm)
PostPosted: Sat May 23, 2020 1:06 am
Last Name: Beaver
City: Lake Forest
Looks like just what I need. Great work!!!
Joe Beaver
Maker of Sawdust
These users thanked the author Joe Beaver for the post: bcombs510 (Sat May 23, 2020 6:06 am)
