It is currently Mon Sep 15, 2025 12:03 am
PostPosted: Tue Jun 30, 2020 6:02 pm
First name: George
City: Seattle
Hi. Well, the threaded adjustment collar (or whatever you call it) on my Performax 10-20 drum sander has finally stripped out. This is the result of a flaw inherent to the design and failure is really just a matter of time. Jet wants $275 for the replacement part. That's a lot of clams for something that's just going to fail again later, so I'd rather find an alternative.
A few years ago there was a guy over on the Uke Underground (Ken Timms) who was selling a repair kit (pic attached). I've written to an old email address I found for him but have not heard back. Anyone know if he's still selling these and/or have current contact info? Anyone know of someone else building the same little gizmo? Anyone have the tools and skills to make one and sell it to me?
George :-)
PostPosted: Tue Jun 30, 2020 6:26 pm
First name: Brad
Last Name: Combs
I don’t know about the repair kit but I will send you his email in PM, at least the one I used a few months back. I was doing a Martin uke repair and he sent me three (three!!!) of his bridges for free.
Brad
These users thanked the author bcombs510 for the post: George L (Tue Jun 30, 2020 6:29 pm)
PostPosted: Tue Jun 30, 2020 7:20 pm
I bet you could cobble something together using a press screw and a block of fine grained hardwood.
https://woodworker.com/9-press-screw-mssu-125-050.asp
Someone gave me several, and I recently cobbled together a bridge clamp with a few of them and some scraps ( an old broom handle and some plywood off cuts from a cabinet mod). The screws self threaded into the plywood so I didn't need the threaded casting shown on the woodworker site, but if the wood strips out I can add them back.
These users thanked the author Clay S. for the post: George L (Tue Jun 30, 2020 9:24 pm)
PostPosted: Wed Jul 01, 2020 7:37 am
Last Name: Colbert
City: Anacortes
Hi George,
Is this any help?
https://www.ereplacementparts.com/jet-1 ... 32862.html
From what I can see in the exploded view, the original style parts are about $120 plus shipping.
Granted, it will still fail again. Happy birthday btw!
Hope you are well, M
These users thanked the author Michaeldc for the post: George L (Wed Jul 01, 2020 9:49 am)
PostPosted: Wed Jul 01, 2020 8:39 am
Any help? -Posts wordwide, about $65 + $30 postage to USA
https://www.ebay.co.uk/itm/Jet-10-20-Performax-repair-kit/274408260445?hash=item3fe401c35d:g:-okAAOSwNIpcrL-C
These users thanked the author Colin North for the post (total 2): George L (Wed Jul 01, 2020 9:40 am) • Michaeldc (Wed Jul 01, 2020 8:52 am)
PostPosted: Wed Jul 01, 2020 9:48 am
First name: George
City: Seattle
Thanks all! I found a reply from Ken in my inbox this morning, with a link to his eBay listing. All's well that ends well. I should have the machine back up and running soon.
George :-)
PostPosted: Wed Jul 01, 2020 9:57 am
Could you share the link please?
PostPosted: Wed Jul 01, 2020 11:23 am
First name: George
City: Seattle
It was the same link you posted above.
George :-)
PostPosted: Wed Jul 01, 2020 2:17 pm
[:Y:]
PostPosted: Wed Jul 01, 2020 3:38 pm
First name: Marcus
Last Name: Bailie
City: Kirkland
FWIW, I used this method of fixing my 10-20. I sold the unit shortly after fixing it, but it seemed to work pretty well.
https://www.amazon.com/gp/product/B0092QWZHY/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
-Marcus
http://www.bailieguitars.com
Instagram | YouTube
PostPosted: Wed Jul 01, 2020 10:05 pm
On a related note, can you describe the issue and why it’s bound to fail? I have a 15 year old 10-20. It works great, but I’m open to preventative maintenance.
PostPosted: Thu Jul 02, 2020 6:07 am
If the lifting rod is threaded into an aluminium or pot metal casting then most likely the problem is caused by a lack of lubrication which leads to galling of the threads. Using "white" (lithium) grease liberally on the threads may help prevent it, But I would be inclined to buy the repair kit while it is available and keep it handy for the eventual "fix" when the threads fail.
https://en.wikipedia.org/wiki/Galling
I had a friend make an adapter ring to mount a Kern level onto a Wild tribrac. The first time test fitting, the fine threads galled and welded themselves together, so now the level is permanently mounted on the tribrac. gaah [headinwall]
PostPosted: Thu Jul 02, 2020 6:47 am
When I heard about this problem maybe 9/10 years ago I was concerned.
IIRC the male/female thread clearances are too big, the female thread is aluminium and runs on a steel male thread.
Lotta weight on it with the motor etc.
I calipered the threads, and found then to be in the dodgy range quoted somewhere on the net.
So I lubricated the thread with copperslip, do it about once/year, due now.
So far, so good, but still nervous about it, it's 12 years old, maybe 13/14 builds. Used it quite a lot, not just ribs and plates.
Helicoil repair kit looks worth a try if it comes to it.
PostPosted: Thu Jul 02, 2020 10:57 am
I don't have a dog in the fight, but the more invasive repair kit might be a more lasting repair. Sometimes helicoils slip, and although they are commonly used to repair stripped spark plug holes (a semi "static" repair) I would be inclined to not use them for a situation where they are constantly being levered against by screw threads. Others may know better and I will admit to limited experience with them.
The kit that is being offered appears to use a steel sleeve in an aluminium block, and since it is in the U.K. the price shouldn't be much more than the helicoil kit ( unless you already have the tap and tool)
These users thanked the author Clay S. for the post: Colin North (Thu Jul 02, 2020 12:40 pm)
PostPosted: Thu Jul 02, 2020 8:16 pm
First name: George
City: Seattle
I read about the issue here several years ago and have applied lithium grease periodically ever since. Even so, I could feel it changing over time. It's definitely a dodgy design. I've only seen positive reports on the repair kit and installation looks simple enough that even I can do it ... maybe. laughing6-hehe
George :-)
PostPosted: Thu Jul 02, 2020 8:38 pm
Thanks, guys.
PostPosted: Wed Jul 15, 2020 7:17 pm
First name: George
City: Seattle
Update: I finally got around to repairing my drum sander with the parts sold by Ken Timms. Everything went smoothly and it seems like the machine is working at least as good as new.
George :-)
PostPosted: Wed Jul 15, 2020 7:29 pm
First name: Brad
Last Name: Combs
Nice! Hopefully Colin found the parts kit too. :)
Users browsing this forum: No registered users and 93 guests
