It is currently Tue Jul 08, 2025 6:48 pm
 Post subject: Strings
PostPosted: Tue Aug 18, 2020 5:12 pm
First name: Ken
Last Name: Nagy
City: Goodrich
I've been on a violin forum, and strings come up a lot. But they are way more money than guitar strings, so people don't really want to buy 3 sets to find the best ones for their instrument. I've never seen anything about strings here.
I need strings for my baroque. I can only find one place that has all guts strings. The low A, (C on mine) is a 1.2mm gut. It seems like a gimped one would work too, (it has wire wrapped in it like a barber pole, so it is a little thinner; maybe 1.0?) but they don't come with that. All the others I've seen have a wound A, if it is fluorocarbon, or a wound A and D with nylons. Even a gut set I saw had a wound low A, or just octave a's.
Would the wound strings tear up the gut frets? It seems like it to me. I would have bought the guts already but I wondered if others would work. But its hard to even find any.
On another note, the high e on my Archtop doesn't excite me much. As you go up, you really have to smash it to get much. It is a heavy nylon e, (.028") I don't remember how the light steel jazz set I had on it sounded. I don't think it wimped out. It's only .010". Maybe just the instrument? Try a lighter string?
Why be normal?
 Post subject: Re: Strings
PostPosted: Tue Aug 18, 2020 5:33 pm
Aquila makes what they call Nylgut strings which I think are supposed to be synthetic gut strings. I use them on my classical guitars and like them.
PostPosted: Tue Aug 18, 2020 5:45 pm
Last Name: Ball
+1 on the Nylguts. I use them on ukes and gut strung banjos--they're not as good as real gut strings, but hold up well and sound good.
I doubt that the wound strings will tear up the gut frets too badly--wound strings in gut sets tend to be wrapped with really fine silver wire.
PostPosted: Tue Aug 18, 2020 6:22 pm
Why not use a harder (and cheaper) fret material - heavy nylon fishing line. It is harder to tie on than gut but should hold up better.
I once used fly rod line to tie a set of frets on a lute. They worked fine but the lime green color was a bit unattractive. :lol:
You can tie nylon the same as gut - it actually makes the (melted) ball ends easier than gut. I do that on nylon trebles to avoid wrapping them around themselves on the bridge tie block - melt a small ball and then just tuck it under itself, same as the metal wound.
https://www.google.com/search?q=tieing+ ... Pk9ibqAs36
PostPosted: Tue Aug 18, 2020 6:40 pm
First name: Ken
Last Name: Nagy
City: Goodrich
I see that you can just.order the strings individually online. Should be easy. I might order a couple of the octave a strings and one a gauge under to try on the other guitar as an e. They have a nylon to nylgut calculator.I
It's worth a try for $7.00
Nylgut is supposedly brighter? Might work.
Nice idea Clay! A bunch of gut to make frets is $70.00. Doubt a fretless baroque would work
Oh I see they sell synthetic fret.gut. I could string it up, and buy each gauge I need.
Why be normal?
PostPosted: Tue Aug 25, 2020 1:40 pm
First name: Ken
Last Name: Nagy
City: Goodrich
I ordered the strings late Friday, and got them this morning. The loaded bass string in RED. Cool.
I'll see how the strings work on the arch top too.
Why be normal?
PostPosted: Tue Aug 25, 2020 3:45 pm
Is the red string a harp string?
PostPosted: Tue Aug 25, 2020 5:07 pm
https://www.stringsbymail.com/?gclid=EA ... gI07fD_BwE
Give this guy a call.
PostPosted: Tue Aug 25, 2020 6:26 pm
First name: Ken
Last Name: Nagy
City: Goodrich
No, it's a !oaded string. They put some sort of metal powder in it when it is made. It is scaled as a 1.25mm string but it.is 1.00. I haven't tried it yet, I need to make a nut.
I did try 3 nylgut strings on the archtop, and it brightened it up, just what I wanted. They are tough to tie. I cut a small piece of thick suede, and put a tiny hole in it.to.keep it from wanting to get sucked into the tailpiece slot. It worked really well.I
The baroque has a loop, to adjust action and even intonation to some extent. I'll have to figure out how to tie it. They aren't as flexible as gut strings.
I don't have to pound the high strings now to get sound out of them. Noticeable. Before they were lost. I went a.gauge or so lower:
.74/.60
.86/.73
1.05/.88
They are denser, so even Steven they are smaller.
Why be normal?
Users browsing this forum: Chris Ide and 29 guests
