It is currently Sat Jul 19, 2025 11:03 am
PostPosted: Sun Sep 13, 2020 12:38 pm
Anyone use this successfully? I've got a vintage project I am working on and after headstock repair have stained with lamp black and I figured if I went right into padding on shellac then I would be basically rubbing the lamp black out so I thought if I spray the shellac on then it will preserve the opaque black. I'm also using it on another project where I had to stain the headstock and want to seal that as well.
I tried warming it up and at room temps and get terrible orange peal with it.
Any tips or tricks would be appreciated.
Regards.
PostPosted: Sun Sep 13, 2020 1:48 pm
First name: Brad
Last Name: Hall
City: Windsor
State: Ca.
Zip/Postal Code: 95492
I’ve used it to seal rosettes and a head plate decal. Several light coats. Worked great.
Brad Hall
Mystic Dawg Guitars
PostPosted: Sun Sep 13, 2020 2:07 pm
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Zip/Postal Code: J2M 1R5
Zinssers aerosol is dewaxed, which is a good thing, but the nozzle is coarse and there is an additive that slows the curing, compared to fresh mixed.
I used it a lot when mixing my own wasn’t possible — now I only use it to seal channels.
Best advice: be very patient. Light coats and oodles of curing time between coats. Avoid the temptation to speed things up with thicker coats.
PostPosted: Sun Sep 13, 2020 3:31 pm
I use it for sealing channels and such, like Tim said. Works fine for that. Not a final finish quality product though, IMO.
PostPosted: Sun Sep 13, 2020 4:15 pm
First name: Jason
Last Name: Moe
City: LaCrosse
State: WI
Zip/Postal Code: 54601
I used it on 2 guitars years ago. If you spray it thick, it takes a long time to dry and can shrink causing hairline checking. It does end up really smooth and shiny. Takes about 2 cans. I do use it for a sealer/protective coat on my tops during building.
Jason Moe
LaCrosse WI 54601
PostPosted: Tue Sep 15, 2020 9:40 am
Yeah I think I was putting it on too thick. It still orange peals though but it did manage to lock in the stain so I could sand the orange peal out and then just continue with FP.
PostPosted: Wed Sep 16, 2020 1:19 pm
City: Escondido
Zip/Postal Code: 92029
I used it once to create a base for FP, and it seemed to work well for that. I’ve been planning on using it again but just haven’t FP’ed a guitar in a couple of years. It didn’t orange peel for me at all. But I do generally have a light hand when spraying. I watched an automotive guy once and couldn’t believe how heavy a coat he would lay on.
PostPosted: Wed Sep 16, 2020 9:54 pm
Last Name: Haney
City: Sugar Land (Houston)
Zip/Postal Code: 77479
I use it to spray around rosette before routing and before cutting out sound hole. I also use it to seal the inside of the guitar which I previously padded on after mixing flakes. The spray looks better inside.
I've never used it for an exterior finish.
These users thanked the author Ed Haney for the post: Pmaj7 (Tue Sep 22, 2020 12:29 am)
