It is currently Mon Jul 21, 2025 1:01 pm
 Post subject: end block dimensions
PostPosted: Fri Oct 09, 2020 12:17 am
First name: peter
Last Name: havriluk
City: granby
State: ct
Zip/Postal Code: 06035
I've noticed on various plans (never took apart an existing guitar to check) that the end blocks are big hunks of wood. So why? Back before electric lights, guitars were made with a friction-fit tapered end pin, but today we can use metal screws that cancel the need for a deep hunk of wood to accept and retain the end pin.
Seems to me that a quarter-inch-thick end plate (block) with a doubler to accept the screw/end pin might work just fine and lighten the guitar a little bit.
I'd love to have this explained to me.
Thanks very much.
Peter Havriluk
 Post subject: Re: end block dimensions
PostPosted: Fri Oct 09, 2020 2:41 am
I normally use mahogany faced birch ply about 14 mm total thickness, tapered at the top of course.
Present or future owners may want an end-jack, and I like to think there's enough strength to resist the odd knock on it.
PostPosted: Fri Oct 09, 2020 5:46 am
they need to be thicker than 1/4 in for sure the torque of a strap pin will split that over time.
I think minimum thickness is 5/8 in
PostPosted: Fri Oct 09, 2020 9:38 am
First name: peter
Last Name: havriluk
City: granby
State: ct
One of the most fixated ideas I've encountered in guitar conversation has been the strap pin. Seems to get a whole lot of genuflection when all that's needed to avoid its drawbacks and threats to the well-being of the instrument is a screwed-in strap attachment. Hence my question about end blocks. I have the idea that there's a cart in front of that horse.
Peter Havriluk
PostPosted: Fri Oct 09, 2020 9:42 am
even with a screw that is enough to crack it
I have been inlaying plywood into my tail block for years
you can't see it from inside the guitar and I make it about 3/4 wide 1/2 in thick
that supports the end block very well. Even a screwed in pin will split a tail block if it gets dropped
PostPosted: Fri Oct 09, 2020 10:00 am
First name: peter
Last Name: havriluk
City: granby
State: ct
All true, John. That's what plywood and crossgrain laminations are for. Nice to get the advice and observations of a professional. Thanks.
Peter Havriluk
PostPosted: Fri Oct 09, 2020 10:40 am
I use 12 mm baltic birch plywood for end blocks. I have seen where some people end it between the linings, but I still glue it to the top and bottom plates.
PostPosted: Fri Oct 09, 2020 11:23 am
I do exactly the same.
PostPosted: Fri Oct 09, 2020 11:28 am
I do the same thing. Works well.
PostPosted: Fri Oct 09, 2020 11:30 am
First name: peter
Last Name: havriluk
City: granby
State: ct
Add one more to the chorus...
Peter Havriluk
PostPosted: Fri Oct 09, 2020 11:33 am
State: West Somerset
Country: UK
High quality plywood, approx. 50 mm wide 15 thick, scalloped down to the lining thickness. The width gives plenty of support to the sides particularly if using a wide tail insert. Dave
Users browsing this forum: JimWomack, Michaeldc and 16 guests
