It is currently Sun Nov 24, 2024 10:38 am
Post new topic Reply to topic  [ 57 posts ]  Go to page Previous  1, 2, 3
PostPosted: Mon Nov 02, 2020 1:46 pm
First name: Charlton
Last Name: Wang
There is this thread over on AGF: https://www.acousticguitarforum.com/for ... p?t=309523
PostPosted: Sun Nov 08, 2020 7:22 pm
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
Here are some photos of my Veritas Twin Screw Vise being used as a Troji, and specifically for buffing the sides with the Adams Mini Swirl Killer.
Here is the vise with the sturdy foam I use:
The foam was arched on the bandsaw to a tighter radius than I use for either the back or top. This allows the foam to grab the edges and not put pressure in the middle of the plates. It is stiff enough foam that mayhem could ensue if you crank the vise too hard on a guitar with flat foam pressing on the plates. The vise screws are covered with short pieces of pipe insulation, which fits just perfectly. All of the foam can be removed in seconds. Note the stepstool under the vise, which is a critical safety feature. It prevents the guitar from falling out the bottom of the vise and hitting the floor.
Here is the vise, with the foam, with a towel covering the foam to provide some cushion for the guitar:
Here is the vise, with the foam, towel, and a guitar:
I tested the buffer, and this arrangement holds the side very well. The towel acts as a sling, because the vise (with the sturdy foam) grips the towel and the guitar edges pretty well. When I press down, the guitar doesn't move, due to the clamping pressure and the towel's sling action.
Now I just need to get better at buffing . . .
These users thanked the author doncaparker for the post: Barry Daniels (Sun Nov 08, 2020 10:29 pm)
PostPosted: Sun Nov 08, 2020 9:20 pm
I used a number of these thing electic and air. I do most on the buffing wheel
Klingspore introduced me to the P grade papers. They have some that are designed to be used
on finishes. I love them. Cut an hour of finish sanding .
I use 2 buff wheels and 3 pastes
and this does all I need to do. I can get very shiney and happy but finish is something we can all discuss , you have to
find the technique that works for you.
One thing is time. I used shirwinn willliams for years but swiched to Mohawk it cured in about 8 days and after 2 weeks the shine
is amazing. SW took about 4 weeks to really cure
PostPosted: Mon Nov 09, 2020 9:50 am
Based on Don's review I just got one of those Adams Mini machines and used it for the first time. Thank you Don that thing is simply fantastic. I just hold the guitar by the neck and let the weight of the machine do the work. Getting close to the neck heal the size of the disk just inches right up to it and it snuggles into all the curves and corners perfectly.
PostPosted: Mon Nov 09, 2020 9:55 am
Last Name: Parker
City: Charleston
Barry Daniels is who we all should thank. Thanks, Barry!
These users thanked the author doncaparker for the post (total 2): Barry Daniels (Fri Nov 13, 2020 9:24 pm) • jfmckenna (Mon Nov 09, 2020 12:39 pm)
PostPosted: Fri Nov 13, 2020 9:23 pm
Just to tie up loose ends, regarding the Adams speed setting. I was buffing today and noticed that I had it set on 2. That's quite slow compared to what it is capable of.
PostPosted: Fri Nov 13, 2020 11:47 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I use the same papers. They are awesom
Users browsing this forum: No registered users and 39 guests
