It is currently Fri Jul 18, 2025 8:36 pm
 Post subject: brace wood
PostPosted: Sat Dec 12, 2020 1:17 pm
Two of these aspects have been discussed at length. The third I do not recall, but that is the only one I am asking for advice.
1) Brace wood is split to assure least runout for vertical grain braces.
2) Horizontal grain braces are perhaps as good or better than vertical grain.
3) My question is, if you use horizontal grain braces, does the runout matter much?
 Post subject: Re: brace wood
PostPosted: Sat Dec 12, 2020 2:59 pm
First name: Ken
Last Name: Lewis
City: Mt. Pearl
State: NL
Lets suppose that
"2) Horizontal grain braces are perhaps as good or better than vertical grain."
Then, if runout didn't matter, I would think that we would all use horizontal grain
for all braces all the time. Just something to think about. But to your question. imo
runout always matters. the less the better.
These users thanked the author Ken Lewis for the post: wbergman (Sat Dec 12, 2020 5:04 pm)
PostPosted: Sat Dec 12, 2020 3:22 pm
I think what he's getting at, is that the run out would not be in the load-bearing direction.
These users thanked the author Pmaj7 for the post: wbergman (Sat Dec 12, 2020 5:04 pm)
PostPosted: Sat Dec 12, 2020 4:49 pm
First name: Ken
Last Name: Lewis
City: Mt. Pearl
State: NL
"I think what he's getting at, is that the run out would not be in the load-bearing direction."
Ah yes, perhaps.
I suppose one could build a guitar with addi or sitka bracing with no regard to grain and it might survive
just fine... or it might not. It's hard to predict the handling it will receive during it's lifetime. I always choose
the best, most runout free, from my pile for the x braces and UTB because not doing so may lead to the chance of
failure that I am not willing to take. Plus, quality straight grained brace wood is fairly easy to come by. 'Course that's
just my opinion. Others may be able to offer a more scientific answer to your question.
PostPosted: Sat Dec 12, 2020 6:37 pm
Runout gets us short grain whether the grain is vertical or horizontal. Maybe it wouldn't matter as much for horizontal grain, but I think it would still matter.
These users thanked the author Pat Foster for the post: wbergman (Sat Dec 12, 2020 8:58 pm)
PostPosted: Sat Dec 12, 2020 6:46 pm
Last Name: Spector
City: ORANGE
Zip/Postal Code: 77632
Seems like not only strenght but the sound transmission/reflection properties would be different in vertical vs. horizontal grain on braces. Maybe someone has tested that.
These users thanked the author surveyor for the post: wbergman (Sat Dec 12, 2020 8:58 pm)
PostPosted: Sat Dec 12, 2020 7:04 pm
Runout occurs when you cut a log across the spiral. So it exists weather it's flat sawn or vertical grain. But in your 3rd scenario you would be gluing the face with runout to the back or top panel and I would think that would lock it up good at least on that one side. Ideally in any orientation you would not want any runout.
These users thanked the author jfmckenna for the post: wbergman (Sat Dec 12, 2020 8:59 pm)
PostPosted: Sun Dec 13, 2020 3:47 pm
First name: Terry
imho, runout in either direction will introduce weakness in your braces. The strength of a split log is the grain running ALL the way through. If your runout is side to side, you are still putting short grained wood in the path of tension, no different than if it was vertical. In fact I might suggest that horizontal runout might actually be worse than vertical in a similar way as a scarf joint with a face plate is stronger than a solid neck with a face plate... again in my humble opinion. Most of this I don't proposed based on having made enough guitars with different brace woods with different grain orientations to have some fail and some not. I say it as a wood worker who has been fiddling with sawn and split woods for various projects for a couple-few decades. I say wood is wood. The only difference between one piece and the next is the density, flexibility/brittleness and stiffness. Once you start tempting the grain fibers to hold together as an insurance policy for your project's strength long term, you are asking for trouble.
These users thanked the author TerrenceMitchell for the post: wbergman (Sun Dec 13, 2020 4:35 pm)
PostPosted: Sun Dec 13, 2020 5:49 pm
Lutes use "horizontally" grained braces.
I don't mind if the grain angles a bit as long as the braces are stiff and don't have much runout.
These users thanked the author Clay S. for the post: wbergman (Sun Dec 13, 2020 6:02 pm)
PostPosted: Sun Dec 13, 2020 7:46 pm
"Lutes use "horizontally" grained braces."
They probably split them off from the edges of the top when it was rough, as classical makers do with fan braces. A lot of the old ways make sense if you think of good wood as being expensive and hard to get, and labor as cheap. We're spoiled by all the good wood we can get.
I often wonder if the late wood lines running out of the scallops at the brace ends would be stress risers, and prone to splitting. Lute braces were not carved down at the ends, but butted tightly into the ribs instead of being inlet into (nonexistent) liners.
These users thanked the author Alan Carruth for the post: wbergman (Sun Dec 13, 2020 8:06 pm)
PostPosted: Sun Dec 13, 2020 10:59 pm
I agree with what you have said above, but would like to add that I don't think the lute makers felt there was any loss of quality by bracing their instruments with the grain oriented this way, and for some reason preferred it.
These users thanked the author Clay S. for the post: wbergman (Mon Dec 14, 2020 6:50 am)
PostPosted: Mon Dec 14, 2020 8:06 am
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
In boatbuilding, I was taught that 12:1 or greater is sufficient to ignore run out. In other words, for a 12" long brace 1" tall, the runout could connect the two opposing corners
Ed M
These users thanked the author Ruby50 for the post: wbergman (Mon Dec 14, 2020 8:24 am)
PostPosted: Mon Dec 14, 2020 8:42 am
Ed M
So using that as a "rule of thumb" a brace 1/4" high and 15" long shouldn't have runout of more than 1 in 60 ?
That sounds reasonable to me.
These users thanked the author Clay S. for the post: wbergman (Mon Dec 14, 2020 12:06 pm)
PostPosted: Mon Dec 14, 2020 9:47 am
I grade each piece of brace wood by flexing it by hand. If it doesn't twist or split or break, if it looks like it will carve without running away, I will use it.
The long X's get more stringent examination, only the best will do.
I'm from the "everything is relative" camp.
If I am building a guitar for the camp any brace wood without actual loose knots will do, and wouldn't you know it, maybe sound better and hold up just as well as your finest guitar.
They are all handmade by a craftsman after all.
These users thanked the author David Newton for the post (total 4): Ernie Kleinman (Tue Dec 15, 2020 5:14 pm) • Colin North (Mon Dec 14, 2020 3:35 pm) • Pmaj7 (Mon Dec 14, 2020 1:34 pm) • wbergman (Mon Dec 14, 2020 12:07 pm)
PostPosted: Mon Dec 14, 2020 10:08 am
First name: Brad
Last Name: Combs
I need to improve at all aspects of material identification and inspection. I come from the tech industry so I cannot fall back on experience with boat building or cabinetry. Can anyone recommend good resources for getting the basics nailed down? I need like some exaggerated images to help visualize it. :)
These users thanked the author bcombs510 for the post: wbergman (Mon Dec 14, 2020 12:07 pm)
PostPosted: Mon Dec 14, 2020 10:43 am
First name: Terry
I think the best way to start understanding this is to take a nice piece of brace wood that you bought from a reputable supplier (expecting that will be essentially straight grain all the way through) and cut yourself out a 24" piece about 1/4" to 3/8" square. Then, take a random piece of lumber that was sawn at a lumber mill (like for building furniture, or even a 2 x 4 from the local home center) and cut he same sized peace.
Then break them both with your hands. You should be able to see quickly what the difference is... and likely feel it too.
These users thanked the author TerrenceMitchell for the post (total 3): Pmaj7 (Mon Dec 14, 2020 1:35 pm) • wbergman (Mon Dec 14, 2020 12:07 pm) • bcombs510 (Mon Dec 14, 2020 11:11 am)
PostPosted: Mon Dec 14, 2020 11:07 am
State: West Somerset
Country: UK
Brad, Bruce Hoadley's Understanding Wood is an excellent book describing how grain runs (with good diagrams) and also how it behaves with moisture.
Cheers Dave
These users thanked the author Dave m2 for the post (total 2): wbergman (Mon Dec 14, 2020 12:07 pm) • bcombs510 (Mon Dec 14, 2020 11:11 am)
PostPosted: Mon Dec 14, 2020 11:12 am
First name: Brad
Last Name: Combs
Awesome, will check it out. Now I have a stocking stuffer. :)
PostPosted: Mon Dec 14, 2020 12:23 pm
Another vote for Hoadley.
These users thanked the author Alan Carruth for the post (total 2): bcombs510 (Mon Dec 14, 2020 3:16 pm) • wbergman (Mon Dec 14, 2020 3:08 pm)
PostPosted: Mon Dec 14, 2020 1:31 pm
In addition to Hoadley, here's another excellent resource for free.
'Wood as an Engineering Material" from the US Forest Service Laboratory.
https://www.fs.usda.gov/treesearch/pubs/37440
These users thanked the author Jim Watts for the post (total 3): TimAllen (Mon Dec 14, 2020 11:13 pm) • bcombs510 (Mon Dec 14, 2020 3:16 pm) • wbergman (Mon Dec 14, 2020 3:07 pm)
