It is currently Mon Sep 15, 2025 12:29 pm
PostPosted: Fri Jan 22, 2021 1:24 pm
First name: Conor
Last Name: Searl
City: Duncan
State: British Columbia
Zip/Postal Code: V9L 2E5
My customer brought this bass to me complaining of intonation issues, and strange tones coming out of the higher register. Other than too much relief the rest of the set up parameters seem normal. These silk wrappings sitting on the saddles can't be good for intonation or tone clarity. Am I wrong?
PostPosted: Fri Jan 22, 2021 1:59 pm
I use an Exacto blade to cut the strings away enough so that it's strictly metal on metal. If the silk tries to unravel, a drop of CA will keep it tight.
These users thanked the author Chris Pile for the post (total 2): Pmaj7 (Fri Jan 22, 2021 5:42 pm) • Conor_Searl (Fri Jan 22, 2021 2:45 pm)
PostPosted: Fri Jan 22, 2021 2:25 pm
First name: Cal
Last Name: Maier
City: Crossfield
State: AB
When I was doing repairs I would keep extra ball ends that came from old used strings to correct this problem. Just slip them over the string in order to space it back so the wrapping does not ride over the saddle.
Just another method!! This works for acoustic bridges on small guitars too, when the wrapping rides up over the saddle.
Cal
BTW you aren’t wrong, it does affect the tone and intonation.
These users thanked the author Cal Maier for the post: Conor_Searl (Fri Jan 22, 2021 2:45 pm)
PostPosted: Fri Jan 22, 2021 2:55 pm
First name: Conor
Last Name: Searl
City: Duncan
Cal
Great idea! But won't work in this case...
PostPosted: Fri Jan 22, 2021 11:52 pm
First name: Cal
Last Name: Maier
City: Crossfield
State: AB
Lol, oh well, someone is always trying to reinvent the wheel. It worked great with some of the more user friendly style of bridges.
PostPosted: Sat Jan 23, 2021 2:08 pm
First name: Conor
Last Name: Searl
City: Duncan
Definitely! I'm going to tuck that one away.
PostPosted: Sat Jan 23, 2021 2:12 pm
I think Fumblefinger did that recently with a repair he undertook, and I've done it on some basses (and guitars). I keep stuff like that, just in case. Washers, and pieces of tubing work, too.
PostPosted: Sat Jan 23, 2021 3:21 pm
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Zip/Postal Code: J2M 1R5
Exactly what I’ve done - also at nut end on low B strings. Then suggest the client find a different brand of string.
PostPosted: Sat Jan 23, 2021 4:19 pm
Yup. Can't forget that sometimes we need to do that at the nut. I put CA on the silk to keep the unraveling to a minimum, too.
Unfortunately, string makers can't accommodate the specs of all instrument makers. So it falls to the luthiers to fix the problem.
cron
