It is currently Sun Jul 27, 2025 6:22 am
PostPosted: Mon Feb 01, 2021 9:03 am
First name: Tom
Last Name: Rein
City: Saline
I am a fan of the metric system, especially in less-than inch measurements. Another plus for the metric system is specific gravity is an easy calculation and it is a unitless measure. Whether your usual method of measuring is metric or Imperial specific gravity is outside the units of these measuring systems.
I do not know how metric weights and volumes work out so perfectly for specific gravity. I don't need to know how but it does.
To determine specific gravity you measure length, width and thickness of a piece in millimeters. Multiply all three measures together to determine volume. Then, divide the weight in grams into the volumetric figure. Once you have this figure, divide it into 1. The decimal point will have to be moved since we calculated in millimeters and kg/m3 is the equivalent of specific gravity.
The net positive is specific gravity is unitless and therefore universal across all measuring modalities.
Maybe it is too much to hope for that suppliers will list the specific gravity of individual soundboards (in particular), but at least a boy can dream.
Stay with the happy people.
--Reynolds Large
PostPosted: Mon Feb 01, 2021 9:36 am
So what does this tell you? That some guitars will float better then others? :D
And just so anyone might want to know, the density of water at 20°C (68°F) is 62.4 lb per cubic foot.
PostPosted: Mon Feb 01, 2021 10:12 am
jfmckenna wrote:
.....................And just so anyone might want to know, the density of water at 20°C (68°F) is 62.4 lb per cubic foot.
Eh? Hombre, no comprende?
These users thanked the author Colin North for the post: jfmckenna (Mon Feb 01, 2021 11:04 am)
PostPosted: Mon Feb 01, 2021 10:18 am
I measure in centimetres and grams, then the calculation just works out to specific gravity, grams/cubic centimetre.
(S.G. of water at 20 deg C is one.)
PostPosted: Mon Feb 01, 2021 10:52 am
Why use specific gravity instead of density?
PostPosted: Mon Feb 01, 2021 11:44 am
First name: Tom
Last Name: Rein
City: Saline
I am no scientist but as I understand it density is mass per unit of volume. Specific gravity is a relative quality with no units. I suppose you could use either measurement to your advantage.
I find specific gravity measure extremely useful in soundboards. I have a range of measurements that I know work well with my style of build.
--Reynolds Large
PostPosted: Mon Feb 01, 2021 12:18 pm
It works out so perfectly because grams are a metric measurement. 1 gram = weight of 1cc of water (originally at STP, then 4 degrees C, now somehow related to Planck's constant [headinwall] )
S.G. = mass/unit volume
Density = mass/ unit volume
S.G. = Density
The reason to use S.G. instead of imperial units (psi, pounds/cu.ft.,tons/cu. yd.) is because it is a unitless measurement it makes calculations easier to do in your head.
PostPosted: Mon Feb 01, 2021 12:26 pm
Specific Gravity is written without units but it is with the understanding that it refers to a specific volume of water. So in effect it carries on the units of its associated reference.
PostPosted: Mon Feb 01, 2021 12:51 pm
First name: Tom
Last Name: Rein
City: Saline
S.G. = Density
Thanks, Clay. Makes perfect sense now that you mentioned how 1 gram came to be defined and its relationship to a volume of water.
--Reynolds Large
PostPosted: Mon Feb 01, 2021 1:00 pm
Clay S -
Thanks for that, I quoted STP. but forgot about the change to 4 C and the anomalous expansion of water thing.
Not so sure about the reference to Plank's constant, or the Hubble-Carmeli time constant, and when i think about it, it's not that often. laughing6-hehe
PostPosted: Mon Feb 01, 2021 1:16 pm
Clay, in you formula above your calculating density not specific gravity. You can calculate density in metric units too. To get specific gravity you divide the density by the density of water which gives a ration of one mass to another.
The density calc is all you need as you point out, if you use grams and cc's you get a number very close to the Specific gravity (waters not quite 1g/cc)
It's not correct however to say the SG = Density, splitting hairs, I know.
PostPosted: Mon Feb 01, 2021 1:22 pm
Any way you calculate it, it's a great way to choose specific tops with particular purpose...
PostPosted: Mon Feb 01, 2021 1:41 pm
Agreed!
PostPosted: Mon Feb 01, 2021 2:28 pm
You are right , at some point you have to add back the units you are measuring in.
PostPosted: Tue Feb 02, 2021 7:29 pm
I’m an amateur marine aquarist if 16years.
I use a refractometer :)
PostPosted: Tue Feb 02, 2021 7:30 pm
Which is useless here ha
Users browsing this forum: stumblin and 9 guests
