It is currently Sun Jul 27, 2025 11:32 am
 Post subject: ELEVATE- New Tool
PostPosted: Fri Feb 05, 2021 9:38 am
Last Name: Ensor
City: Springfield
State: Missouri
IT’S HERE! You’ve been asking for a more versatile M&T Routing Jig and you’ve been heard. Introducing the Variable M&T Routing Jig. All the same great features as the original with the added benefit of adjustable length. Get yours today. https://www.ElevateLutherie.com/product/v-mt-routing-jig/
http://elevatelutherie.com
http://ensorguitars.com
These users thanked the author Chris Ensor for the post: Pmaj7 (Fri Feb 05, 2021 2:06 pm)
 Post subject: Re: ELEVATE- New Tool
PostPosted: Fri Feb 05, 2021 2:07 pm
How do you "clamp everything down"? Does locking the pivoting part provide enough pressure to keep it tight for routing or do you need to add external clamps? I don't see any in the video.
PostPosted: Fri Feb 05, 2021 2:27 pm
First name: Chuck
Last Name: Skarsaune
City: Butler
I was just having that same thought.
I would grab the body and jig all in a body clamp/vise.
I’ll rewatch that video in a minute.
Edit - when he routs the body, you can see the clamp screw clamping the jig to the guitar body.
The neck looks like it is clamped in a typical body / bench vise, along with the jig.
PostPosted: Fri Feb 05, 2021 3:35 pm
I see the clamp screws when he's doing the neck but not the body. Seems like the body would be the hardest to fasten securely to the jig and most critical.
PostPosted: Fri Feb 05, 2021 3:40 pm
Last Name: Ensor
City: Springfield
State: Missouri
Yes, you definitely need to firmly clamp the jig to the part being routed. The screws simply lock in the angle. On the body, clamping through the sound hole is advised- being careful not to damage the UTB.
These users thanked the author Chris Ensor for the post: Pmaj7 (Fri Feb 05, 2021 11:25 pm)
PostPosted: Sat Feb 06, 2021 11:39 am
What if you just made it hook around the guitar body like a U channel? It'd be easy enough to add adjustability for a radiused back.
PostPosted: Sat Feb 06, 2021 3:29 pm
If it is designed for a bolt on neck there may something to be said for making the mortise very slightly bigger than the tenon for a little wiggle room in alignment. (At least having that option) I am not sure I see any real advantage to a snug fit in that application.
I have been doing a mortise and tenon bolt on for many years and found that at least for my purposes a slightly loose fit was helpful especially in tweaking axial alignment. The old StewMac plexiglass templates were designed that way. Not sure if they still are.
That option and a more secure attachment system to the body for the body mortising jig wound make this nice looking device more attractive to me.
cron
