It is currently Sun Sep 21, 2025 4:20 am
PostPosted: Tue Feb 16, 2021 3:30 pm
First name: Terry
I'm about to do my first headstock with a binding that has a single perfling of ~.020" on the inside. Some of the surfaces are flat, which is no big deal, but I do have a couple edges that have curves. Normally, I use a bending iron to bend the pieces, but with the perfling I'm trying to figure out if I can glue the two together and then bend it, or if I need to bend the thicker outside piece and let the inner thin piece go along for the ride during glue-up.
Any advice from those who have done this sort of thing?
Thanks in advance.
PostPosted: Tue Feb 16, 2021 4:39 pm
I usually do the last option (bend the thicker outside piece and let the inner thin piece go along for the ride during glue-up). The .020 purfling should cold bend easily during the glue up, assuming it is not a brittle wood. You could do a dry run to see if this will work. Laminating the strips ahead of time actually makes it a bit more difficult to get a gap free job, especially on curved surfaces.
These users thanked the author Barry Daniels for the post: TerrenceMitchell (Tue Feb 16, 2021 4:49 pm)
PostPosted: Thu Feb 18, 2021 10:39 am
First name: Terry
FYI.... using the recommended approach worked great. Plus the outer pieces were a little thinner than what I usually use (thinner by the perfling width) and that made them much easier to bend around some of our tight curves on the headstock.
PostPosted: Thu Feb 18, 2021 12:46 pm
State: West Somerset
Country: UK
Pics...? Dave
Users browsing this forum: Colin North, DennisK and 37 guests
