It is currently Sun Nov 24, 2024 4:35 am
 Post subject: Gummy spots on nitro
PostPosted: Fri Feb 19, 2021 2:08 pm
I'm doing a crack repair on a '90s kamaka which I think is nitro. Using CA like normal, but when I go to scrape it I noticed some of the areas around and under where I put the ca are gummy. Did not notice any gumminess before I started. I did use Napa and a toothbrush to clean out the area as I was initially super gluing slivers in the crack area. Could that have caused the gumminess? What to do?
Gummyness in Seattle
 Post subject: Re: Gummy spots on nitro
PostPosted: Fri Feb 19, 2021 3:43 pm
CA will interact with NITRO did you use accelerator? let it set a day or so it may reharden the more I do this the less I use CA
These users thanked the author bluescreek for the post: Pmaj7 (Fri Feb 19, 2021 3:45 pm)
PostPosted: Fri Feb 19, 2021 3:46 pm
Yes, I used accelerator. Gluboost accelerator and CA
PostPosted: Fri Feb 19, 2021 4:35 pm
How old is your CA? Over time it absorbs water and gets thick. That's why I buy new bottles every year, and toss the old ones. Fresh glue is a MUST, no matter what type.
These users thanked the author Chris Pile for the post: Pmaj7 (Fri Feb 19, 2021 4:58 pm)
PostPosted: Fri Feb 19, 2021 4:56 pm
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
I just started using Gluboost accelerator. I do like the performance, but it can temporarily soften old nitrocellulose lacquer. In my experience, the lacquer will harden back up after a few hours.
My old standby accelerator is Insta Set in a squirt bottle. It does not soften lacquer, but it will cause some super glues to blush (turn white or milky).
Sent from my SM-G950U1 using Tapatalk
These users thanked the author John Arnold for the post (total 2): Hesh (Mon Feb 22, 2021 6:37 am) • Pmaj7 (Fri Feb 19, 2021 4:58 pm)
PostPosted: Fri Feb 19, 2021 11:21 pm
Seems like it has hardened up. Okay no more accelerator! Thanks guys!
PostPosted: Sat Feb 20, 2021 2:33 pm
So I scraped off most of the gummy and let the area harden. Then I put some new Gluboost fill n finish on and let it dry overnight. Most of it is hard but the area that was gummy, the ca did not harden! Hmm....
Users browsing this forum: Colin North and 29 guests
cron
