It is currently Fri Jul 25, 2025 9:19 am
 Post subject: New to me bandsaw
PostPosted: Sat Aug 14, 2021 2:49 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I finally got myself a 26" bandsaw!! Now it will be a nice addition to my shop, but the crap 14 inch bandsaw has got to go. I was told I have to move out by the end of september due to my shop being recalled by the government due to rezoning.
Here's some picture.... bicycle tire as scale reference (it's a 26" bike tire). Bandsaw uses a big handwheel for adjusting the height of the upper wheel, but the tension is held with a weight besides the saw. Meaning I need to find a way to lift the weight in order to change blades. I'm thinking of using a pneumatic cylinder that I got off of a neighbor's CNC machine to replace the weight with something a little more controllable.... The cylinder was malfunctioning due to a worn out seal, and the neighbor who owns the CNC machine bought a new one and threw the old one out. I may be able to use it to hold tension and vary it based on air pressure... But anyways the saw itself uses a weight hanging from a lever, using the mechanical advantage to actually apply tension. If you need more tension, add more weight.
These cuts were done in 10 minutes flat, on a dull blade. Looks like the Acacia finally dulled the blade too much... I think bimetal/carbide is better served here. Probably Woodmaster CT or Woomaster B...
Factory image of this particular model. Has a 5HP 3 phase motor.
Paid about 1000 dollars for the saw, purchased with my tax refund from 2017. Thank you, IRS.
Typhoon Guitars
 Post subject: Re: New to me bandsaw
PostPosted: Sat Aug 14, 2021 3:16 pm
City: Tyler
Wow that is a beast! Good buy
PostPosted: Fri Aug 20, 2021 3:07 pm
First name: Corky
Last Name: Long
City: Mount Kisco
Nice
PostPosted: Fri Aug 20, 2021 5:42 pm
Last Name: Gleason
City: Kurtistown
State: Hawaii
Zip/Postal Code: 96760
Most small to medium size bandsaws are tensioned with springs and handwheels. I don't know why anyone would use weights. I do have a friend who uses weights as a power feed for resawing to pull the wood through the saw. trange process, but it works for him. I think I'll stick with my electric powerfeed and spring tensioned resaw.
“ The meaning of life is to find your gift and the purpose of life is to give it away” Pablo Picasso
Users browsing this forum: Bing [Bot], Dave Rickard and 9 guests
