It is currently Mon Jul 21, 2025 9:24 am
 Post subject: CA as a finish?
PostPosted: Thu Sep 16, 2021 7:55 am
Anyone tried it on an acoustic?
 Post subject: Re: CA as a finish?
PostPosted: Thu Sep 16, 2021 8:17 am
I have only used CA for touch-ups on acoustic guitars. I have finished entire bass necks with it, and it's durable and good looking. It's hard work to do that, and I did it outside to keep the fumes at bay.
PostPosted: Thu Sep 16, 2021 8:35 am
You might be just as well off brushing polyester gaah
PostPosted: Thu Sep 16, 2021 8:40 am
Last Name: Orr
you would need a hell of a lot of CA! Wouldn't it be very expensive and I would think you may need some heavy duty, fresh air fed, respirator as the fumes are nasty!
Also doesn't it stain spruce end grain? Would need to keep it away from the top or seal with several layers of shellac first.
PostPosted: Thu Sep 16, 2021 8:58 am
I finished an ebony fretboard for a fretless bass with it once and didn't like the slightly sticky feeling it left. Different brands would probably give different results.
PostPosted: Thu Sep 16, 2021 9:45 am
I have use thin CA as a pore filler and it worked fantastically. I thought about it as a finish too but it's just not out there yet. I have seen some wood turners who used it on things like pens.
PostPosted: Thu Sep 16, 2021 12:21 pm
I have seen demos of the Glu Boost brand, which is designed for this, and know one maker who uses it on acoustics. It's formulated to have little or no odor.
PostPosted: Thu Sep 16, 2021 1:35 pm
Last Name: Gramann
City: Fredericksburg
State: VA
Zip/Postal Code: 22408
I used Gluboost on a chisel handle that I turned. I rubbed it on as the handle spun on the lathe. For a least a couple of months, that handle had quite a plasticky feel when I used it. A couple of years later, it’s still a bit plasticky. I won’t be doing that again.
PostPosted: Thu Sep 16, 2021 4:34 pm
If it feels like plastic, you made it too smooth.... Hitting it lightly with gray Scotchbrite will break the surface tension enough for a smooth and satiny feel, while leaving the shine intact. It's not much different than scuffing a lacquer or poly finished neck on new guitars.
PostPosted: Fri Sep 17, 2021 9:16 am
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
Some CA's exist that are good for polyester finish touch-ups, but generally lack the finishing -ilities (e.g., sprayability/brushability/tintability) of purpose-formulated polyurethane and polyester finishes. Some CA materials may see color change, etc. as the material ages, so another reason to verify that the material is suitable for long-term use and is tintable or otherwise suitable (e.g., may be pad-applied) for the intended use.
- Beth Brower
PostPosted: Fri Sep 17, 2021 10:50 am
I may be off, but didn’t Dana Bourgeois develop a CA finish for their torrefied guitars?
PostPosted: Fri Sep 17, 2021 5:06 pm
Yes, he has.
PostPosted: Fri Sep 17, 2021 6:39 pm
First name: Freeman
Last Name: Keller
A warning - I have become hypersensitive to some CA's and must wear a respirator any time I work with it. Trying to finish a guitar with it would probably finish me.
These users thanked the author Freeman for the post: Colin North (Sat Sep 18, 2021 2:53 am)
PostPosted: Sat Sep 18, 2021 7:36 am
Hi Colin I thought that I remembered a prior thread about CA as a finish and I found a few. Here's one, hope this helps.
https://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=43613&p=577716&hilit=+CA+as+a+finish+#p577716
These users thanked the author Hesh for the post: Chris Pile (Sat Sep 18, 2021 2:56 pm)
PostPosted: Sat Sep 18, 2021 11:43 am
Thanks Hesh.
These users thanked the author Colin North for the post: Hesh (Sun Sep 19, 2021 11:26 am)
PostPosted: Mon Sep 27, 2021 5:13 am
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
I developed the sensitivity almost 30 years ago. I have been using odorless CA ever since. It has the added advantage of not attacking lacquer, so it works great for touchups. I once finished an entire neck with it, but was not satisfied with the look or the feel.
PostPosted: Mon Sep 27, 2021 7:08 am
Many of us tried it at one point
it can turn spruce yellow there are many better finish products out there.
Was an early fan of glu boost but it has a short shelf life and no longer use it.
I am using star bond CA .
CA's are great for some uses but I think it does get over used.
PostPosted: Mon Sep 27, 2021 7:18 am
I also find CA useful for touch ups but am not interested in using it as a finish. Interestingly I do not find Glu Boost to have a shorter shelf life then other CA products that I use (like StewMac or Hot Stuff). I used to use Hot Stuff but years ago I had a bottle split just sitting on the shelf, made a hell of a mess, and I won't use that anymore. I haven’t tried Starbond.
PostPosted: Mon Sep 27, 2021 3:02 pm
First name: Roy
Last Name: Machin
City: Mexborough
State: South Yorkshire
Zip/Postal Code: S64 0HW
Country: United Kingdom
The only time that I`ve used it as a finish was recently on an ebony headstock veneer and it worked very well. I usually french polish but because I had already drilled the tuner holes the pad snagged and it was difficult to get a level finish.
I stopped the tuner holes with foam earplugs, cut them flush and applied three coats of medium CA. It was ugly lumpy but after block sanding through the grits to 1500 and then micromesh I am pleased with the outcome.
We`ll see how it goes but I imagine that it will not be as vulnerable as shellac.
Roy
These users thanked the author stumblin for the post: Colin North (Mon Sep 27, 2021 3:03 pm)
Users browsing this forum: JimWomack and 20 guests
