It is currently Thu Aug 07, 2025 12:46 am
PostPosted: Fri Apr 07, 2006 11:36 am
Can someone with an open box of Waverley tuners measure the hexagonal bushing for Craig. He's doing the inlay on the FOLK Guitar Project and doesn't have the final dimensions of the bushing.
I got him the specs from StewMac website, but the drawings do not give the final hexagonal measurements of the bushing, only the tapered part of the press in outside of the bushing.
TIA
It would be helpful to get the dimension of the flats side to side, and the corners of the hexagon, corner to corner.
PostPosted: Fri Apr 07, 2006 12:42 pm
First name: Craig
Last Name: Lavin
City: Sunrise
State: Fl
Zip/Postal Code: 33323
I really need it to make sure the bushing doesn't cover up the eye.
Maybe you can tell me this- I am currently 3mm from the outer edge of the tuner hole to the inlay. Is this enough space to include the bushing in full? It "looks" like enough but that's not good enough!
Craig L.
www.handcraftinlay.com
PostPosted: Fri Apr 07, 2006 12:44 pm
0.3735 flat to flat
0.4250 point to point
PostPosted: Fri Apr 07, 2006 12:47 pm
they are .3760" inches across measured with at set of calipers.
PostPosted: Fri Apr 07, 2006 12:49 pm
Didn't see your post JJ. There must be a litle variation in these.
PostPosted: Fri Apr 07, 2006 1:46 pm
Or the two calipers...
PostPosted: Fri Apr 07, 2006 11:04 pm
First name: Craig
Last Name: Lavin
City: Sunrise
State: Fl
I'm on it.
Craig
