It is currently Sun Sep 14, 2025 7:36 am
PostPosted: Mon Nov 08, 2021 8:35 am
Hello dear colleagues,
I am trying to bring back to life an older Guild JF 65-12 steelstring guitar.
Despite a neck reset and a refret, I need to replace a missing piece of the Balck / White / Black binding at the headstock.
I do not have this kind of platsic (?) binding in the fitting thickness.
I am more the wood-binding type of guitarmaker, and also we do not have so many sources for this kind of material here in Europe.
My question:
Perhaps somebody here as the perfect matching material, or perhaps even a small piece of original GUILD binding which would
do the job a s good as possible? I think 2-3 inches would be more than enough...
Placed in an envelope, I think it should be easy to send to me Germany. Of course I pay the shipping costs!
I attached some pictures for easier understanding.
So, is there anybody with some leftovers of some Guild repairs who is willing to help me?
Thank you very much in advance, cheers, Alex
AND....can somebody help me with dating the guitar and the serial number:
JF650388
By using this homepage I do not find a matching result:
But I guess 1988 ?
http://support.guildguitars.com/downloa ... rguild.pdf
PostPosted: Mon Nov 08, 2021 10:50 am
First name: peter
Last Name: havriluk
City: granby
State: ct
Zip/Postal Code: 06035
just a thought - - - it may be more productive to look for two pieces of binding, the thinner black&white for one and the thicker all-white for the other. I suspect that these are of more standard dimensions.
Peter Havriluk
PostPosted: Mon Nov 08, 2021 12:46 pm
Looks like pretty standard binding/purfling to me. I agree with Peter that it would be best to piece it together because you will have a hard time finding an exact match that is already laminated together. It looks like the inner white strip is thicker than the black line. I could send you some miscellaneous oversize pieces that would probably work but you would have to size them to match.
PostPosted: Tue Nov 09, 2021 8:27 am
Thank you so far for your comments.
Yes, probably I have to use just "normal" binding material, perhaps in seperate layers.
Which is fine and no problme at all.
I was just hopeing that you guys over in the USA have all boxes in your workshops full with old original Guild binding material ... ;)
Would just be nice if the material is really the same and the color would match perfectly.
Perhaps I am lucky and someone has some stuff left over...
Cheers, Alex
PostPosted: Tue Nov 09, 2021 9:59 am
Last Name: Spector
City: ORANGE
Zip/Postal Code: 77632
I just received some 1.5mmx1.5 from a company over there called "Northwest Guitars" in Cheshire England. Maybe they will have something.
These users thanked the author surveyor for the post: Herr Dalbergia (Tue Nov 09, 2021 10:08 am)
PostPosted: Tue Nov 09, 2021 10:08 am
Thank you Surveyor, I will have a closer look....
PostPosted: Fri Nov 12, 2021 9:27 pm
I used varying layers of .020 stewmac black and white. Laminated with the little stewmac tool and solvent.
PatImage
These users thanked the author Pmaj7 for the post: Herr Dalbergia (Tue Nov 16, 2021 1:46 am)
