It is currently Sat Jul 26, 2025 6:58 am
PostPosted: Tue Jun 21, 2022 7:06 pm
First name: doug
Last Name: powdrell
City: hilo
State: big island
After 5 years of moderate use, the height adjusting screw finally gave out.....
Looks like 8 hex screws to remove the shroud/housing to release the screw.....have the new part...supplier had minimal advise....
Just checking before I delve into it.....
Inboard sandpaper clip is another....back-ordered for a while....been using medium viscosity CA with good results! Sometimes hi-tech isn't the best way...?
Thanks in advance......
PostPosted: Tue Jun 21, 2022 8:16 pm
First name: peter
Last Name: havriluk
City: granby
State: ct
Zip/Postal Code: 06035
Any power tool maintenance shops available? These folks make their living keeping shop tools alive, and if they haven't seen that partricular problem, they've seen enough similar ones.
Peter Havriluk
PostPosted: Tue Jun 21, 2022 11:11 pm
First name: doug
Last Name: powdrell
City: hilo
State: big island
Done...gotta remove the drum....aprox. 16 hex screws and misc stuff.....give yourself 1 hr....need 3 sizes to remove hex screws....Not that complicated....just dont mix up threads, etc....
probably similar to replacing inboard clip.......
PostPosted: Wed Jun 22, 2022 12:58 am
First name: Roger
Last Name: Häggström
City: Örnsköldsvik
Zip/Postal Code: 89136
Country: Sweden
That happened to me too. The height adjusting screw is threaded in the soft aluminum cast, a terrible design. To fix it, the threaded hole must be drilled bigger and an insert in hard metal with threads matching the screw mounted. Not a problem if you have the tools and the right threaded insert.
New will change the old,
turn to ashes or gold
http://www.gammelgura.se
PostPosted: Wed Jun 22, 2022 11:06 am
First name: Marcus
Last Name: Bailie
City: Kirkland
For me, it was the actual hole that stripped and couldn't grip the threaded bolt any longer. I used a thread repair kit and it worked fine for me. Dunno if that helps at all.
https://www.amazon.com/gp/product/B0092QWZHY/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
-Marcus
http://www.bailieguitars.com
Instagram | YouTube
These users thanked the author Marcus for the post: Pat Foster (Wed Jun 22, 2022 5:43 pm)
PostPosted: Wed Jun 22, 2022 5:06 pm
First name: doug
Last Name: powdrell
City: hilo
State: big island
Wow!!! Thanks guys! yep, it's the aluminum hole that is stripped!! Marcus THANK YOU for the referral on amazon for like $50. You guys are the best!
PostPosted: Thu Jun 23, 2022 4:02 am
Last Name: Bradley
Country: United Kingdom
There is a guy from the UK who makes repair kits for these, because the manufactures parts are still not up to it apparently. His kits are sometimes available online. His name is Ken Timms and can be found and contacted through the UkuleleUnderground forum by the name "Timbuck". He also has Youtube videos showing how to use the kits, search for Ken Timms .
PostPosted: Thu Jun 23, 2022 8:26 am
Marcus,
Thanks for that info. Was it the 9/16-18 that comes up in your link?
PostPosted: Thu Jun 23, 2022 10:37 am
First name: Marcus
Last Name: Bailie
City: Kirkland
Marcus,
Yessir, 9/16-18
-Marcus
Instagram | YouTube
These users thanked the author Marcus for the post: Pat Foster (Thu Jun 23, 2022 11:27 am)
Users browsing this forum: joe white and 24 guests
