It is currently Fri Jul 04, 2025 3:00 am
PostPosted: Thu Sep 15, 2022 9:14 am
First name: Tom
Last Name: Armstrong
City: Portsmouth
Zip/Postal Code: 23701
A Pandoras Box question.
What solvents do you use to clean your spray equipment and how to you dispose of the left over waste?
PostPosted: Thu Sep 15, 2022 10:40 am
Last Name: Colbert
City: Anacortes
Hi Tom,
I mostly shoot waterborne topcoats, so warm water. I also shoot shellac which I make with grain alcohol, I use the alcohol to flush my guns - this I save for cocktails later that evening.
M
PostPosted: Thu Sep 15, 2022 10:41 am
What waterborne are you using?
PostPosted: Thu Sep 15, 2022 10:50 am
Last Name: Colbert
City: Anacortes
Target EM6000
PostPosted: Thu Sep 15, 2022 12:08 pm
Thanks!
PostPosted: Thu Sep 15, 2022 3:01 pm
I clean the gun by spraying lacquer thinner through it after soaking the parts in thinner in the cup. I only do a full breakdown if the gun isn't spraying properly. Used thinner can be saved and used to strip finishes or clean up overspray. If I had to buy it I use it until it's used up. [:Y:]
PostPosted: Thu Sep 15, 2022 3:24 pm
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
I figure you clean with the solvent/thinner for the finish you are spraying, right? If I am spraying Royal Lac, I clean with alcohol. If I spray UV cured finish, I clean with acetone.
