It is currently Fri Jul 18, 2025 7:33 pm
PostPosted: Sun Nov 13, 2022 5:07 pm
First name: Viktor
Hi, everyone,
I recently finished an archtop with a Sacconi tailpiece (like Benedetto). It turned out really well, except that the ebony endpin (Stewmac) broke while the guitar was hanging on the wall. (I must not have been home, as I'm sure I would have heard it.) My music room was just a little drier than usual, so I suppose it may have loosened a bit before breaking.
In any case, for those of you who build this style: what do you use for an endpin? I have a separate strap button, so it just holds the Benedetto tailpiece fastener--which is a lot of tension. It could be something like brass instead of ebony. I just want it to be reliable.
I'll post pictures of the guitar when I get an endpin back in--for anyone who is curious.
Viktor
PostPosted: Sun Nov 13, 2022 5:26 pm
Use a heavier endpin.
PostPosted: Sun Nov 13, 2022 5:39 pm
First name: Viktor
Heavier would be great. I’m not sure where to find one.
PostPosted: Sun Nov 13, 2022 6:26 pm
In 40 plus years at the bench, that is a first for me. Perhaps that pin was damaged or had issues during manufacturing? I suggest simply trying another ebony pin.
PostPosted: Sun Nov 13, 2022 8:26 pm
First name: Viktor
My guess is that I didn’t fit it well and may not have had it seated deep enough. It’s probably more me than the endpin.
These users thanked the author berberiv for the post: Hesh (Mon Nov 14, 2022 3:05 am)
PostPosted: Mon Nov 14, 2022 3:08 am
Hi Viktor is there anything unusual about the strings in terms of string gauges? If you're not using 70's (I have two clients that do on arch tops) a properly seated and fit pin of the same size from another source might be fine too especially if you think your fitment of this pin was off.
Let's see your Archie too, we love pics :)
PostPosted: Mon Nov 14, 2022 1:51 pm
I'm lucky and have a small lathe. Very easy to turn to the larger dimensions (not tapered) shown in the Benedetto book for me. All of mine have been African Blackwood or the endpin jack that StewMacs sells that are designed for the cable.
PostPosted: Mon Nov 14, 2022 6:33 pm
First name: Viktor
I decided to turn a slightly larger one myself, in African blackwood. I don’t have a lathe but it was small enough to do in a drill press.
I think I’ll do my own too from now on. It didn’t take more than a few minutes.
Thanks for all the comments. I’ll send pictures in a day or so.
Viktor
PostPosted: Tue Nov 15, 2022 9:29 pm
Online
City: Escondido
Zip/Postal Code: 92029
Somewhere in the dark past of this forum I posted about an end pin that broke under tension. It exploded like a cherry bomb in my lap as I was playing it. [FLUSHED FACE]
fortunately all the energy was directed outward so I was undamaged. But in the immortal words of Sid the Sloth “I think I did something involuntary… and messy”. For the next couple of guitars I used a brass end pin.
PostPosted: Sat Nov 19, 2022 11:54 am
First name: Viktor
Hi, everyone,
For the curious, I turned a new (very plain) endpin to replace the one that snapped.
I borrowed the shape of this guitar from Nicola Moffa's Lorraine with f holes I saw on an old Hofner (I think). It's fully hollow and parallel-brace. I attached the P90 to a very small block glued across the braces, and I used thumbwheel tone and volume controls under the tailpiece. I really just wanted to try out something with a P90.
Thanks again,
Viktor
These users thanked the author berberiv for the post: TimAllen (Sun Nov 20, 2022 2:03 am)
PostPosted: Sun Nov 20, 2022 9:20 am
berberiv wrote:
Hi, everyone,
Thanks again,
Viktor
Looks great Viktor!
PostPosted: Sun Nov 20, 2022 8:43 pm
First name: Viktor
Thanks, Darrel.
Viktor
Users browsing this forum: Gasawdust and 14 guests
