It is currently Thu Jul 24, 2025 7:28 pm
 Post subject: Number 6
PostPosted: Fri Dec 02, 2022 5:34 pm
First name: Garrett
Last Name: Colllier
I had some photos done by a family friend who did a remarkable job.
Engelmann spruce, Katalox back and sides, Koa binding and pick guard. Image
These users thanked the author apostleguitarcompany for the post (total 6): Durero (Tue Dec 13, 2022 1:11 am) • Ken Nagy (Sat Dec 03, 2022 10:13 am) • Clay S. (Fri Dec 02, 2022 9:11 pm) • Michaeldc (Fri Dec 02, 2022 7:06 pm) • bcombs510 (Fri Dec 02, 2022 7:00 pm) • Chris Pile (Fri Dec 02, 2022 6:06 pm)
 Post subject: Re: Number 6
PostPosted: Fri Dec 02, 2022 7:01 pm
First name: Brad
Last Name: Combs
Lovely!
How was the katalox to bend? I have a tenor uke in the works that is katalox.
These users thanked the author bcombs510 for the post: apostleguitarcompany (Fri Dec 02, 2022 10:32 pm)
PostPosted: Fri Dec 02, 2022 9:16 pm
Beautiful guitar, very well done. Black and white with golden accents.
These users thanked the author Clay S. for the post: apostleguitarcompany (Fri Dec 02, 2022 10:32 pm)
PostPosted: Fri Dec 02, 2022 10:32 pm
First name: Garrett
Last Name: Colllier
bcombs510 wrote:
Lovely!
Thank you!
It wasn’t too bad. I’ve bent it by hand before on a homemade iron and it took forever! Could have been mostly inexperience.
This build I used the LMI bender. Heat at 300 and each side took around 10 minutes to complete the bend. I took my time and it went well.
It was quite brittle though and I had a split after bending when I was trimming it down. CA glue made it an unnoticeable repair though.
These users thanked the author apostleguitarcompany for the post: bcombs510 (Sat Dec 03, 2022 3:03 am)
PostPosted: Sat Dec 03, 2022 10:17 am
First name: Ken
Last Name: Nagy
City: Goodrich
Koa binding? I thought it was tourtise shell plastic (spellcheck is NOT helping) Very nice. I've used katalox for fingerboards, and fittings/pegs. One piece labeled roayl ebony, the cream part was almost as hard as the black.
Nicely done.
Why be normal?
These users thanked the author Ken Nagy for the post: apostleguitarcompany (Sat Dec 03, 2022 2:00 pm)
PostPosted: Sat Dec 03, 2022 11:31 am
I really like the curly Koa binding. Very nice guitar!
These users thanked the author SteveSmith for the post: apostleguitarcompany (Sat Dec 03, 2022 2:04 pm)
PostPosted: Sat Dec 03, 2022 1:31 pm
Wowsa!
These users thanked the author Colin North for the post: apostleguitarcompany (Sat Dec 03, 2022 2:04 pm)
PostPosted: Sat Dec 03, 2022 2:04 pm
First name: Garrett
Last Name: Colllier
Nicely done.
Yes, the pictures are a bit dark so I see what you mean. I’ll attach a couple under the full shop lights, pre buffing, so you can see it a little better.
It is very hard wood indeed. I’ve also used it for fingerboards and bridges, but am really liking it for back and sides as well.
I got the lumber for this at woodcraft and then milled it myself to get this set. I think that back and side set cost me about $15 doing it that way.
These users thanked the author apostleguitarcompany for the post: Robbie_McD (Mon Dec 12, 2022 10:41 am)
PostPosted: Tue Dec 06, 2022 10:13 am
You have an "orange peel" surface on your finish there. Might want to look into eliminating that because it will affect the finish clarity.
These users thanked the author Barry Daniels for the post: apostleguitarcompany (Tue Dec 06, 2022 1:36 pm)
PostPosted: Tue Dec 06, 2022 1:38 pm
First name: Garrett
Last Name: Colllier
Yes, you are correct sir.
I was really struggling to get the spray gun dialed in this go around. Turns out it was just too low of pressure, but I didn’t get it worked out until the last day of spraying.
I spent a LOT of time wetsanding to get it all flat.
PostPosted: Wed Dec 07, 2022 12:06 pm
Glad you got it worked out.
I latter realized that orange peel is not the correct diagnosis for this. Orange peel has pits that is created by too much air pressure. What you were dealing with was poor atomization that basically created droplets of lacquer accumulating on the surface that were not giving a full wet coat, but a bunch of droplets bonded partially together. And as you said, dialing up the air pressure is the cure.
These users thanked the author Barry Daniels for the post: Robbie_McD (Mon Dec 12, 2022 10:42 am)
PostPosted: Sun Dec 11, 2022 5:50 pm
What a great looking guitar, kinda makes me want to burn my numbers 6 and 7 I'm working on :P
Did you make the pickguard or buy it? Self sticking, spray adhesive or double-sided tape? Also curious what the thickness of the pickguard is.
Any plans for the next one?
Great work
These users thanked the author LaurieW for the post: apostleguitarcompany (Mon Dec 12, 2022 8:29 pm)
PostPosted: Mon Dec 12, 2022 8:37 pm
First name: Garrett
Last Name: Colllier
Great work
Please don’t burn any guitars! Haha!
I made the pickguard out of a solid piece of Koa. I have a drum sander which makes it easier to thin down, though I did my first one by hand. I don’t remember the exact thickness, maybe 1mm-1.5mm?
I have used double sided tape in the past and it worked fine. However, on this one I used the adhesive sheets that stewmac sells. I like it more than double sided tape, just a little easier to use.
I have a Koa OM that I’m spraying finish on currently. I’ve also started a Bubinga Dreadnaught that’s in early stages as well.
Thanks for the compliments, I appreciate it!
These users thanked the author apostleguitarcompany for the post: LaurieW (Tue Dec 13, 2022 5:57 am)
PostPosted: Tue Dec 13, 2022 5:59 am
I'd love to see the koa OM if you are interested in posting pics [:Y:]
PostPosted: Tue Dec 13, 2022 12:02 pm
First name: Garrett
Last Name: Colllier
Sure thing! I should have strings on it next week if all goes as planned. I’ll make a post for it.
PostPosted: Tue Dec 13, 2022 12:31 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Looks nice! I love that koa guard. Well done.
Bryan Bear PMoMC
These users thanked the author Bryan Bear for the post: apostleguitarcompany (Tue Dec 13, 2022 3:10 pm)
PostPosted: Thu Dec 15, 2022 5:29 pm
Great work!
These users thanked the author James Orr for the post: apostleguitarcompany (Thu Dec 15, 2022 8:54 pm)
