It is currently Tue Sep 16, 2025 12:17 am
 Post subject: sander R/O
PostPosted: Fri Jan 06, 2023 5:54 pm
Last Name: McNerney
City: Ottawa
State: On
Country: Ca
I am thinking about getting a 3" R/O sander (and maybe for buffing too) (and what size orbit is acceptable) so it's a bit easier to get in to the waist area. I don't have a large compressor so the palm style sanders, which would be my first choice, are probably not going to work for me unless someone has experience which this type using a smaller compressor.. As far as electric goes there are some cheaper ones by companies I've never heard of that I might consider. I'd like to hear from anyone that uses one or has another method for sanding & polishing the waist area
Mike McNerney
 Post subject: Re: sander R/O
PostPosted: Fri Jan 06, 2023 10:05 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I have been down this rabbit hole so much. Mirka has what you need in the old style sander. 3", ROS, small stroke. I almost went that way until I found a solution with Festool (did not want air tools). For me it was 3mm stroke, 3" and 5". Festool has that. But I found very similar solutions with Mirka. Airflow is the key thing.
With Mirka, so much to look at. Self generating vacuum, non-vacuum. Ugh. But there are kits to convert. Here is the one I think you might like:
https://buymirka.com/collections/mr-san ... ro-mr-3sgv
2.5mm good for finish work, 5mm good for aggressive work.
PostPosted: Sat Jan 07, 2023 7:06 am
Just a small question, for buffing a finish I was under the impression a larger orbit was the way to go.
I've been using a 12mm orbit DA polisher, like an Adams polisher.
PostPosted: Sat Jan 07, 2023 8:49 am
I’ve got the Festool RO90. It’s a 3 1/2”. It works for me and I found I use it more than I expected. Too bad Festool tools are so so expensive.
PostPosted: Sat Jan 07, 2023 9:00 am
My Festool cordless drill and 5" ROS and big-arse dust "extractor" are all 17 years old now and they have all performed beautifully and in a commercial environment too.
Dave prefers less expensive drills and he's gone through three of them to my single Festool making mine less expensive. ;). I have had to replace the battery and check this out the original charger that came with my drill was engineered to be forward compatible with battery tech changes and advances. So when I purchased my single replacement battery the charger still works great with it and it's also 17 years old.
Good stuff
These users thanked the author Hesh for the post: Durero (Sat Jan 07, 2023 5:29 pm)
PostPosted: Sat Jan 07, 2023 12:31 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
In the sanding world, smaller orbit equals less aggressive. I have the Adams polisher too. And if you are using the glaze like me, you know that it has almost no buffing grit. But, I cannot exactly answer your question. Maybe someone who understands car buffing can.
PostPosted: Sat Jan 07, 2023 12:36 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
That is the one I am getting (working sides of guitars). 125 ETS for the rest. Both have 3mm orbit. The RO90 worries me with that rotex setting. In Rotex mode, it becomes a beast. Gonna tape mine lol!
PostPosted: Sat Jan 07, 2023 2:40 pm
Was just using it in that aggressive
Mode. It is a beast but the selector is well marked and it doesn’t move easily.
These users thanked the author SteveSmith for the post: Hesh (Sun Jan 08, 2023 3:36 am)
PostPosted: Mon Jan 09, 2023 7:38 am
Last Name: McNerney
City: Ottawa
State: On
Country: Ca
I'm much closer to the end of my career and can't see spending the money for festool or mirka as much as I would like to. I will probably try the cheapo zota or manusage maybe a metabo at 280. do you need interface pads in the waist area for fine sanding & polishing.
Mike McNerney
PostPosted: Mon Jan 09, 2023 11:33 am
First name: John "jd"
City: Santa Barbara
I have the 90mm metabo. Nice sander with excellent dust collection when connected to a vacuum.
Only down side is the grip is on the large side.
I use a soft pad when sanding anything that is not flat.
