It is currently Thu Jul 24, 2025 8:13 pm
Post new topic Reply to topic  [ 1829 posts ]  Go to page Previous  1 ... 31, 32, 33, 34, 35, 36, 37 ... 74  Next
PostPosted: Wed May 03, 2023 1:14 pm
First name: Howard
Last Name: Wilson
I believe it was West System 3 this time.
These users thanked the author Doc for the post: doncaparker (Wed May 03, 2023 1:26 pm)
PostPosted: Wed May 03, 2023 10:10 pm
Last Name: Itzkin
State: NY/Granada
Country: USA/Spain
joshnothing wrote:
Looks beautiful, I bet the winner must have been thrilled. What oil finish did you use?
Thanks! The winner likes it considerably more than his previous Kenny Hill guitar and plans to use it for his Julliard audition later this year. I used Liberian finishing oil as does Kevin Aram. Aram wrote a tutorial for applying this finish in American Lutherie no 127, fairly easy to apply but requires considerably more prep work including sanding the guitar to 2400 grit micro mesh.
These users thanked the author oval soundhole for the post: Durero (Fri May 05, 2023 3:38 pm)
PostPosted: Sun May 07, 2023 11:45 pm
First name: Josh
“My buddy tried to fix it by squeezing some more glue underneath and clamping it back down.”
These users thanked the author joshnothing for the post (total 3): jfmckenna (Wed May 17, 2023 8:05 am) • Hesh (Mon May 08, 2023 1:29 pm) • Chris Pile (Mon May 08, 2023 9:14 am)
PostPosted: Mon May 08, 2023 9:14 am
Yeah, that always works... (eyeroll)
These users thanked the author Chris Pile for the post: Hesh (Mon May 08, 2023 1:29 pm)
PostPosted: Wed May 10, 2023 1:49 pm
Checking out a new tower binding jig.
Linear rails and bearings with DeWALT D26200 router and counterweight.
Image[img]
Sent from my moto g(50) using Tapatalk
These users thanked the author Colin North for the post (total 8): Robbie_McD (Thu Jun 08, 2023 6:58 pm) • Michaeldc (Sun May 28, 2023 1:51 pm) • jfmckenna (Wed May 17, 2023 8:05 am) • SteveSmith (Wed May 10, 2023 7:29 pm) • Durero (Wed May 10, 2023 6:28 pm) • Hesh (Wed May 10, 2023 6:21 pm) • bcombs510 (Wed May 10, 2023 2:36 pm) • Chris Pile (Wed May 10, 2023 2:21 pm)
PostPosted: Tue May 16, 2023 8:47 am
Some progress after a bout of Covid.
EIR/torrefied Sitka, flame maple bindings, polar burr rosette and tailpiece.
Bindings fitted and Sound Port cut
Apologies about the pic sizes.
These users thanked the author Colin North for the post (total 6): Chris Pile (Sun Jun 04, 2023 10:20 am) • Michaeldc (Sun May 28, 2023 1:51 pm) • Hesh (Sat May 27, 2023 3:38 am) • jfmckenna (Wed May 17, 2023 8:05 am) • bcombs510 (Tue May 16, 2023 9:06 am) • joshnothing (Tue May 16, 2023 9:00 am)
PostPosted: Fri May 26, 2023 9:29 pm
First name: Josh
Just off the bench: a ‘69 J45 I posted about earlier. It had cracks, loose bracing, cracked bracing, missing bracing requiring replacement, destroyed threads for the adjustable saddle (customer opted to repair and keep rather than delete this hardware), a lifting bridge that was warped and missing so much wood it required replacement. And the fella wanted a K&K pure mini installed.
These users thanked the author joshnothing for the post (total 4): Skarsaune (Mon Jun 05, 2023 6:51 am) • Michaeldc (Sun May 28, 2023 1:52 pm) • Hesh (Sat May 27, 2023 3:38 am) • Chris Pile (Sat May 27, 2023 12:00 am)
PostPosted: Fri May 26, 2023 10:29 pm
A big Honkin 18” Archtop almost done.
These users thanked the author Brad Goodman for the post (total 8): Robbie_McD (Thu Jun 08, 2023 6:59 pm) • jfmckenna (Mon Jun 05, 2023 2:37 pm) • Michaeldc (Sun May 28, 2023 1:52 pm) • Hesh (Sat May 27, 2023 3:38 am) • joshnothing (Sat May 27, 2023 2:34 am) • Colin North (Sat May 27, 2023 1:59 am) • Chris Pile (Sat May 27, 2023 12:00 am) • bcombs510 (Fri May 26, 2023 11:15 pm)
PostPosted: Sun May 28, 2023 11:22 am
Last Name: Itzkin
State: NY/Granada
Country: USA/Spain
Just finished up this homage to Torres FE-13 for Brandon Acker. Top is old Swiss spruce from Andres Marvi, European Birdseye maple maple back and sides, ebony binding and fretboard, madagascan rosewood bridge and head plate, strung with nylgut strings
These users thanked the author oval soundhole for the post (total 9): Bryan Bear (Fri Feb 16, 2024 12:56 pm) • steveci (Fri Jun 23, 2023 2:21 am) • Chris Pile (Sun Jun 04, 2023 10:21 am) • Ken Nagy (Sun Jun 04, 2023 9:21 am) • joshnothing (Mon May 29, 2023 5:28 am) • Durero (Sun May 28, 2023 3:26 pm) • Michaeldc (Sun May 28, 2023 1:52 pm) • Hesh (Sun May 28, 2023 12:19 pm) • bcombs510 (Sun May 28, 2023 11:25 am)
PostPosted: Sun May 28, 2023 11:59 am
Last Name: Spector
City: ORANGE
Zip/Postal Code: 77632
I started collecting hurricane debris wood several years back and decided to build an OM from it. 1st pic of the headstock inlay. The top and peghead overlay are what many would consider "unusable/undesirable" lighter pine and the back and sides are red oak.
anywho, that one didn't stay too long, some guy from Louisiana " had to have it" so I started a dreadnaught
These users thanked the author surveyor for the post (total 3): Michaeldc (Sun Jun 04, 2023 7:22 pm) • Chris Pile (Sun Jun 04, 2023 10:22 am) • Hesh (Sun May 28, 2023 12:20 pm)
PostPosted: Sun May 28, 2023 12:02 pm
Last Name: Spector
City: ORANGE
Yikes! I must have not sized that last pic correctly.
PostPosted: Sun May 28, 2023 1:28 pm
Flossing the neck.
Goes much quicker after I started routing the undercut in the cheeks (instead of chiseling it) leaving about 4mm width of contact each side, 3mm after fitting the board and trimming the neck.
Also introducing my hi-tech neck alignment tool designed using the KISS principle.
Strip of perspex with a series of holes drilled to fit short steel rods which go into the truss rod slot, and to draw fine black marker lines at the butt end ( wow7-eyes OH! - can I say that, or will it auto-correct?)
These users thanked the author Colin North for the post: Hesh (Mon Jun 05, 2023 3:42 am)
PostPosted: Sun Jun 04, 2023 9:33 am
First name: Ken
Last Name: Nagy
City: Goodrich
I'm basically a hack butcher compared to many here, but I finally put strings on the cello last night. I started it 10 years ago. Made the fancy 3 layer form, roughed the belly, did a bad job slicing the back wedge, and tried to salvage it to no avail; so it sat. Found a slab for the back, and made a back for my archtop with part of it, and then finally made the cello back. In the winter I dropped it, and had to replace 2 ribs, and that turned out like nothing happened at all. The forum works really good.
It still needs a new sound post fit, I think it needs to be longer. The bridge is still way too high. The nut is too high. I need some touchup where I had to file the neck to match the fingerboard. The fingerboard is Surinam? Ironwood. 1.33 sg. very hard stuff. It wasn't that hard to make. Put the taper on, carve a 70mm radius on the top, with some relief. Straight forward stuff.
I had to make a peg shaper for the pegs. They were 14mm at the head. Too big. I usually make pegs. A REAL shaper is $150 or so. I made one by reaming two tapered holes, a small and a bigger for the top and end of the pegs, making a notch in the board to clamp on a plane blade that I use as a scraper. It worked. Not great, but it worked.
The nut and saddle need to be polished up. Both cracked. Apparently the one end of the Ironwood board had checking that I didn't notice.
But the strings are on!
A cello sounds like it it an octave below a guitar to me. More like a bass. I tuned it with the archtop, and it was like I was tuning octaves!
Why be normal?
These users thanked the author Ken Nagy for the post (total 7): Robbie_McD (Thu Jun 08, 2023 7:01 pm) • Skarsaune (Mon Jun 05, 2023 6:53 am) • Hesh (Mon Jun 05, 2023 3:42 am) • Michaeldc (Sun Jun 04, 2023 7:23 pm) • J De Rocher (Sun Jun 04, 2023 11:41 am) • Chris Pile (Sun Jun 04, 2023 10:23 am) • bcombs510 (Sun Jun 04, 2023 9:44 am)
PostPosted: Sun Jun 04, 2023 9:45 am
Ken Nagy wrote:
I'm basically a hack butcher compared to many here, but...
Don't beat yourself up too much. I don't see anyone else here taking on a project like building a CELLO! Congrats on getting to the finish line.
PostPosted: Sun Jun 04, 2023 2:39 pm
First name: D
Last Name: S
Waiting for lacquer spraying weather. I used 3M professional masking tape and sprayed the purple lacquer with an air brush. I had no bleed-through or rough edges.
wah
Wah-wah-wah-wah
Wah
These users thanked the author dzsmith for the post (total 4): bcombs510 (Mon Jun 05, 2023 12:14 pm) • Hesh (Mon Jun 05, 2023 3:43 am) • Michaeldc (Sun Jun 04, 2023 7:23 pm) • Chris Pile (Sun Jun 04, 2023 3:13 pm)
PostPosted: Mon Jun 05, 2023 11:20 am
First name: Marcus
Last Name: Bailie
City: Kirkland
I'm working on 5 guitars and I need to drive the bus on all of them. It was such a daunting thought to do this to all of them in a shop that's 85 degrees. So I finished up my dish sanding system that I started up a few years back. This isnt the final design, i had to replace a lot of the parts with more appropriate ones. Ive also added two dust ports to the shroud.
I am also trying out some different clamps for fitting and gluing my linings. This is the first attempt. After this session i realized it would be better to flip them so they clamp from the inside.
-Marcus
http://www.bailieguitars.com
Instagram | YouTube
These users thanked the author Marcus for the post (total 3): Michaeldc (Mon Jun 05, 2023 12:34 pm) • Hesh (Mon Jun 05, 2023 12:20 pm) • bcombs510 (Mon Jun 05, 2023 12:16 pm)
PostPosted: Mon Jun 05, 2023 12:19 pm
First name: Brad
Last Name: Combs
Marcus, in the last pic, is that an outer shell that is used to stabilize the side while clamping in the lining?
I’m playing with the idea of doing the Collings approach of having a caul baked into the mold. It’s interesting that you’re clamping without the mold.
Also, do you clamp from the inside because then the weight of the clamp is actually pinching the joint closed at the bottom (meaning the part that is no routed for binding).
Brad
PostPosted: Mon Jun 05, 2023 2:38 pm
First name: Marcus
Last Name: Bailie
City: Kirkland
Brad
No, this side is actually just a cornucopia of laminated wood. The original intent (of this particular guitar) was to have maple laminated with maple (with carbon fiber between). I absolutely roasted the inner maple set on my bender somehow so it got pretty dark. I decided to laminate the inside with some Mac ebony veneer.
With that buildup the sides are super, super stiff, so I dont really need an outside mold.
I will now clamp from the inside of the mold because the clamping part (that is attached to the bolt) is a narrower profile. This way i can add a small caul and get more center-focused clamping pressure. Its not a huge deal on the straight parts, but with those big sweeping curves, it appears to be a bit of an issue.
Here's a little illustration of the "problem"
-Marcus
Instagram | YouTube
These users thanked the author Marcus for the post: bcombs510 (Mon Jun 05, 2023 4:04 pm)
PostPosted: Mon Jun 05, 2023 10:25 pm
Better to have narrow points of contact when clamping on curves.
PostPosted: Sat Jun 10, 2023 9:59 am
Awesome stuff as per usual from all OLF'rs around here.
This is the first time I have tried this sharpening system and... Call me a convert!
These users thanked the author jfmckenna for the post: Hesh (Sun Jun 11, 2023 4:21 am)
PostPosted: Sat Jun 17, 2023 1:51 am
First name: Josh
Spent this morning doing blasphemous things to a 100-year-old 0-size guitar
Another luthier has already very nicely rebraced the soundboard for steel strings but sadly the non-reinforced neck couldn’t take the tension and it developed a permanent forward set. The fret board was also starting to loosen around the body joint. After this rod install, a neck reset is also on the cards as well as a few loose back braces.
These users thanked the author joshnothing for the post (total 2): Michaeldc (Sat Jun 17, 2023 6:04 am) • Hesh (Sat Jun 17, 2023 3:59 am)
PostPosted: Sat Jun 17, 2023 9:03 am
After watching the Bashkin documentary and with a couple of backs to join I tried his go-bar method. I must say it worked just fine.
ImageIMG_8684 by Terence Kennedy, on Flickr
ImageIMG_8686 by Terence Kennedy, on Flickr
These users thanked the author Terence Kennedy for the post (total 3): Hesh (Sat Jun 17, 2023 11:10 am) • bcombs510 (Sat Jun 17, 2023 10:38 am) • Chris Pile (Sat Jun 17, 2023 10:28 am)
PostPosted: Sat Jun 17, 2023 10:40 am
First name: Brad
Last Name: Combs
As mentioned, beveling the frets. Got a tip from Dave Farmer to wax up the masking tape runway. Working good so far!
These users thanked the author bcombs510 for the post (total 3): Hesh (Wed Jun 21, 2023 3:11 am) • James Orr (Sat Jun 17, 2023 6:41 pm) • Durero (Sat Jun 17, 2023 4:57 pm)
PostPosted: Wed Jun 21, 2023 1:25 am
I’m working away on this clone of a Two-Rock John Mayer Signature amp here and there during the evening after the girls have gone to sleep. I don’t remember exactly how many amps I’ve put together, but I’d guess 5 or 6, with the last being thirteen or fourteen years ago. There was support then, but the level of documentation and resources has really soared and made this very approachable as the neuroplasticity kicks in and I remember this and that. There’s enough to get you going, but also enough to force some decision-making. I.e. am I going to make it 100 or 50 watts, and what needs to be done to make that work?
One enthusiast in particular (Ryan at http://thetonegeek.com) has been a god send.
These users thanked the author James Orr for the post (total 2): Hesh (Wed Jun 21, 2023 3:12 am) • bcombs510 (Wed Jun 21, 2023 2:20 am)
PostPosted: Wed Jun 21, 2023 3:13 am
Very cool!!! I remember an amp you did over ten years ago that you made a nice wooden face for the cab and finished it. It was beautiful. Please post a pic of that one James if you have one? That was some of my early inspiration to try amp building which is great fun!!
These users thanked the author Hesh for the post: James Orr (Wed Jun 21, 2023 8:14 pm)
Users browsing this forum: jfrench and 16 guests
