It is currently Tue Apr 29, 2025 4:20 pm
Post new topic Reply to topic  [ 58 posts ]  Go to page 1, 2, 3  Next
PostPosted: Fri Apr 14, 2006 3:58 am
With so many experienced builders here I was very curious what bracing style you have found best for you. Is it some form of parabolic or is it scalloped, and what do some of the other well-known, very successful builders do/use?
Greg
Gwaltney Guitars
PostPosted: Fri Apr 14, 2006 4:01 am
scalloped for me, but I am not well known or successful
PostPosted: Fri Apr 14, 2006 4:07 am
I have found that "Klingon" bracing gives me the sound that I am looking for in my guitars. I prefer my scallops pan-fried
PostPosted: Fri Apr 14, 2006 4:09 am
Last Name: Beaver
City: Lake Forest
What is the Klingon brace? Sounds interesting.
Joe Beaver
Maker of Sawdust
PostPosted: Fri Apr 14, 2006 4:15 am
[QUOTE=Joe Beaver] What is the Klingon brace? Sounds interesting.[/QUOTE]
Joe,
Just my pet name for p*******c bracing, which as some people are quick to point out is not exactly p*******c in shape
PostPosted: Fri Apr 14, 2006 4:47 am
I use hyperbolic. It's way more impressive.
PostPosted: Fri Apr 14, 2006 4:50 am
Iused scalloped on my first and will do both types on #2 and #3 (twins but different) and will compare the 2 types!
PostPosted: Fri Apr 14, 2006 4:51 am
Hey Hesh,
Those shadows look pretty parabolic to me
So it's Moonburst on the inside and Sunburst on the outside - way cool!! (Mind you, like Don I still think an "Hour Before Dawn Sunburst" would be better when the Adi shines out in the moonlight)
PostPosted: Fri Apr 14, 2006 5:04 am
All prejudices aside, I'm really curious which style has won over the ears of the buying public and why. I used a form of parabolic on my first guitar and it sounded great, but wonder sometimes what a scalloped version would do.
Greg
Gwaltney Guitars
PostPosted: Fri Apr 14, 2006 5:47 am
As Mario MAY say: It's not necessarily the shape that matters, but how light/stiff you make it. Mass is what dampens sound, shape may have something to do with it, but you glue a big piece of wood in the box that shouldn't normally be there and it doesn't matter what shape it is, it's still going to dampen the vibration of the top.
So Try both, like Hesh there has done and listen to the difference, now of course you will have used two different tops, b&s and braces, but you should be able to hear some sort of difference.
Of course for acurate testing, the braces should all be the same weight and stiffness for a good parabolic versus scalloped brace challenge.
Having said all this, I've done scalloped for my first 4 and I have a friend who is making his with parabolic.
I'm sure both designs make great sounding guitars, as we have seen with some of the high end builders.
PostPosted: Fri Apr 14, 2006 6:24 am
Howard, hyperbolic is great, especially given the discussions around the issue!
[QUOTE=Dave White] which as some people are quick to point out is not exactly p*******c in shape [/QUOTE]
How about cyberbolic? parabolish?burbank38821.6421064815
PostPosted: Fri Apr 14, 2006 6:31 am
Well, I shouldn't be revealing this, but the secret of some of the pros is using
anabolic. Makes the guitars so powerful it's almost like cheating.
PostPosted: Fri Apr 14, 2006 6:42 am
First name: Coe
Last Name: Franklin
City: Decatur
Scalloped for me. That`s just how I chose to do it, though.
PostPosted: Fri Apr 14, 2006 6:43 am
   I tried scalloped on my first. I think I will try parabolic on the second, or maybe not.
PostPosted: Fri Apr 14, 2006 7:00 am
I guess I use both.
All my braces are arched   ???parabolic????
And then I scallop the X braces
PostPosted: Fri Apr 14, 2006 7:10 am
[QUOTE=Howard Klepper] Well, I shouldn't be revealing this, but the secret of some of the pros is using
anabolic. Makes the guitars so powerful it's almost like cheating.[/QUOTE]
Yeah, but after a while their bridges shrivel and they get just plain mean.
PostPosted: Fri Apr 14, 2006 7:23 am
Yes, but you should never have any problem with the bridge lifting because you would have such a good Bond.
                        Paul Harrell
PostPosted: Fri Apr 14, 2006 8:28 am
[QUOTE=Rod True] As Mario MAY say: It's not necessarily the shape that matters, but how light/stiff you make it. Mass is what dampens sound, shape may have something to do with it, but you glue a big piece of wood in the box that shouldn't normally be there and it doesn't matter what shape it is, it's still going to dampen the vibration of the top.[/QUOTE]
I agree with this assessment, which is why I have switched from scalloped to parabolic bracing. All other things being equal, a parabolic brace, because of its arched shape, should be able to withstand more force or tension than a scalloped brace. With classical bracing patterns, I am able to have less mass glued down to the top using parabolic braces than I do using scalloped ones, while still maintaining the same level of stiffness.
The proof is in the pudding, though. The two guitars I'm working on right now are the first ones I've built using all parabolic bracing. It'll be interesting to see if there is a noticeable difference.
Best,
Michael
Live to Play, Play to Live
PostPosted: Fri Apr 14, 2006 11:28 am
Well said Michael.
PostPosted: Fri Apr 14, 2006 8:25 pm
"Parabolic". It seems much better suited to modern playing styles.
Dave, if it's truly Klingon bracing, maybe if it could go cloaked it would reduce the overall mass of the top.
ColinColin S38822.2285416667
PostPosted: Fri Apr 14, 2006 8:36 pm
Some of you guys should quit making guitars and start doing standup
comedy. My wife is sitting here asking what I'm laughing at. I don't really
know how to respond.
Would you guys say parabolic is easier to make? (can't wait for your
answers)
Ross
PostPosted: Fri Apr 14, 2006 8:38 pm
Also, do you guys cut your braces short to stop at the lining or tuck?
Thanks.
Ross
PostPosted: Sat Apr 15, 2006 3:27 am
Unfortunetly when you do this - you start with a 25.5 neck scale and end up with a 21.3 after a few years,
woh woh wohhhhhhhhhh
and "mean as hell" as someonee else said - but who wouldnt be with such a tiny neck,
Charliewood
PostPosted: Sat Apr 15, 2006 4:31 am
Last Name: Beaver
City: Lake Forest
I like the looks of Hesh's 'parabolic' braces. I'd love to know how they sound!
Where did the term parabolic come from anyway? It is cool sounding but I doubt the shape can be represented with y2=2py.
Joe Beaver
Maker of Sawdust
