It is currently Sat Sep 13, 2025 10:52 pm
Post new topic Reply to topic  [ 33 posts ]  Go to page Previous  1, 2
PostPosted: Sun Sep 24, 2023 11:47 am
I think, it's OK now.
PostPosted: Sun Sep 24, 2023 3:18 pm
String it up and let's see...
PostPosted: Sun Sep 24, 2023 7:41 pm
First name: Pierre
Last Name: Castonguay
City: Québec, Qc
I wouldn't think so judging from the pic. Remember that glue will not fill voids so what you see now is what you'll get.
Hesh gets great results with a scraper, but he has a lot of mileage under his belt. Although I too remove the bulk using scraper, I find it easier to finalize fit with sandpaper. FWIW, here's what I do, as many others do as well from what I gather. I stick wide low-tack tape on the top, then on top of it I stick 120 grit sandpaper (same style as what we use for frets, only coarser). Then I simply rub the bridge until it conforms precisely to the top without any wobble or visible gap.
You'll get a perfect fit this way, as well as painful fingers if you do it often enough. At least this old geezer finds it increasingly painful.
Pierre
Guitares Torvisse
Pierre Castonguay
PostPosted: Mon Sep 25, 2023 1:11 pm
I just wanted to let you know guys that your advice and suggestions
have not fallen on deaf ears and I will make every effort to make the job done properly. [:Y:]
Usually I’m a ‘it’s good enough’ person but in this case I need to change gears.
The bridge has to fit perfectly if I don’t want to watch it loosen again.
See you in few days!
These users thanked the author Rob2023 for the post: Hesh (Mon Sep 25, 2023 11:12 pm)
PostPosted: Mon Sep 25, 2023 6:26 pm
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Zip/Postal Code: J2M 1R5
Smylight wrote:
joshnothing wrote:
Smylight wrote:
[quote="Hesh"]Some decent bolt-ons are the Godin line which includes Seagull, A & L and about four other brands.
Hey Hesh,
As you know I'm in Quebec, home of Godin, so I get to see a whole lot of them in my shop.
Sadly, they decided some years ago to go to a different, industrial process for their neck joints. It is a thick sandwich made of interlocking wood parts held together with a good measure of epoxy. Techs at Godin have advised me that the joint is not serviceable and the neck has to be sawn off and replaced if service is required.
I was also told that because the joint is SO strong, no reset should ever be needed. Talk about wishful thinking…
I have once tried dismantling one and it was a right nightmare; once the extension gets loose (after having fought the epoxy), the interlocked wood pieces inside still make sure you won't ever get the thing undone. Now I tell my poor customers that their Godin-made guitar is not serviceable when (not if) it finally needs a reset. But I will gladly welcome any hint from fellows who have discovered a way to save those guitars… short of sawing the neck off. ;-)
Pierre
Guitares Torvisse
Pierre, thanks for this information. Do you know what year approximately this change was made?
From what the tech guys at Godin tell me, post-2006 cannot be reset without sawing them off. I do see lots of those in need of a reset, sadly.
Pierre
Guitares Torvisse[/quote]
Pierre is exactly right about the change to the Godin neck joint. I’ve seen them new from the music store needing a reset. The Godin tech I talked to (while calling about another Godin failure) was part of the R&D team that “designed” the joint with epoxy. He was quite proud of eliminating the need for a reset. Yeah, right.
BTW, the only indication that the instrument has the “improved” neck joint is the serial number — they otherwise look identical. Depending on the exact model, the changeover coincided almost exactly with the switch from 8-digit to 12-digit serial numbers.
These users thanked the author Tim Mullin for the post (total 2): Hesh (Mon Sep 25, 2023 11:12 pm) • Smylight (Mon Sep 25, 2023 7:23 pm)
PostPosted: Mon Sep 25, 2023 11:13 pm
You're doing fine my friend we are all here to learn and we are happy to help when we can. [:Y:]
PostPosted: Wed Sep 27, 2023 12:03 pm
Hi Guys!
So I’m done with the sanding.
The bridge fits the top of the guitar really tight now.
It’s not glued yet but I will do it tomorrow.
I had to sand the top in the area of the bridge as well
to make it more smooth and even.
As the result of it you can see now the wonderful texture of Madagascar Acacia ... muhahaha! laughing6-hehe
See you!
PostPosted: Fri Sep 29, 2023 12:35 am
I dunno it may be an optical illusion but that bridge sure continues to look crooked to me. The saddle slot is engineered to be crooked and further back on the bass side but the leading edge of the bridge should be 90 degrees to the centerline of the neck.
cron
