It is currently Fri Jul 18, 2025 6:59 pm
PostPosted: Thu Jul 04, 2024 7:58 pm
First name: peter
Last Name: havriluk
City: granby
State: ct
Zip/Postal Code: 06035
While I've never seen one, I'd like to try to use burl-figured (name the species) wood on a head plate and for a fingerboard. Any idea as to what I need to be looking for? Or where?
Thanks!
Peter Havriluk
PostPosted: Thu Jul 04, 2024 8:36 pm
Last Name: Kincheloe
I love burls, especially maple and walnut. Hard to find, though. I snagged a good slice of maple from Hibdon maybe 10 years ago, but all I have for walnut is a sliced veneer sheet.
I'd recommend looking for a 1/8" thick slice rather than a full fingerboard sized piece. Glue it to a backing board and cover up the edges with binding. If it's not long enough, you can use multiple pieces and hide the joints between frets. Saturate it with CA glue to harden and dirt-proof it.
I used a maple burl headplate on one of my harp ukuleles.
PostPosted: Thu Jul 04, 2024 8:47 pm
City: U.P.
As Dennis pointed out, burl may not be tough enough for a fingerboard but as he said, you can toughen it up with CA. The other problem is, it is hard to find fingerboard size pieces of burled wood.
An alternative would be "quilted, birdseye maple" which is almost as crazy grained as burl, hard and tough enough for a fingerboard and available at lengths suitable for fingerboards and necks, etc.
Just mentioned this place to Bill and they have some fine examples of what I was thinking about for you.
Have a look -
https://www.curlymaplewood.com/BMTB-109-1-1316x19-34-Quilted-Birdseye-Hard-Maple-Turning-Square_p_15445.html
Brian R, Wood Mechanic
N8ZED
PostPosted: Fri Jul 05, 2024 1:07 pm
Burls are by nature unstable, but CA takes care of that really well. I'd recommend saturating with the CA before gluing to the headstock - keeps you from having pieces chipping off, etc., and makes it easier to work with. This was Amboinia burl and ebony. Many burls to choose from.
PostPosted: Fri Jul 05, 2024 1:57 pm
gilmerwood.com
off and on they have instrument billets of camphor or amboyna burl...nice HUGE chunks of this wood
I can make no comment about it's suitability for any specific purpose...sure can be pretty though
PostPosted: Fri Jul 05, 2024 5:35 pm
I have quite a bit of maple burl I sliced up years ago. Large enough for head plates. Let me know if you want any for the price of shipping. I’ll take a pic when I find it.
These users thanked the author Darrel Friesen for the post: phavriluk (Sat Jul 06, 2024 8:04 pm)
PostPosted: Fri Jul 05, 2024 8:34 pm
First name: Carl
Last Name: Dickinson
City: Forest Ranch
Zip/Postal Code: 95942
Hey Peter,
If you want to try Manzanita burl, I've got sliced pieces you can use whole or butterfly. Milled with the grain so not as porous as endgrain. It is an eight inch diameter burl (I've got a bunch more) and like Dennis said you could glue pieces to a backing to create a fretboard and bind it with Manzanita. I've got a bunch of fretboard sized pieces of Manzanita I've been using on several recent builds, you've probably seen them on Acoustic Guitar Construction Forum . Also pieces I've used for binding on the body, fretboards, headstocks and soundholes. It bends pretty easily. If you want to try some let me know and we can work out the shipping.
These users thanked the author CarlD for the post: phavriluk (Sat Jul 06, 2024 8:13 pm)
PostPosted: Sun Jul 07, 2024 8:50 am
Manzanita might be one of the few burls I would consider for a fingerboard. Most burls are too soft and unless hardened with some sort of penetrating resin would wear quickly. Having an irregular grain, Manzanita may be a bit "twisty", but I have only worked with small pieces, so others may know better how it is.
Users browsing this forum: oval soundhole and 27 guests
