It is currently Sat Jul 19, 2025 2:28 am
PostPosted: Wed Sep 25, 2024 3:17 pm
Last Name: Curran
City: Pietrasanta
State: Lucca
Zip/Postal Code: 55045
Country: Italy
When I buy blanks for braces, they come in a set of 8 or so. I get them pre-thicknessed (to 8 mm).
I've been sorting them depending on number of growth rings, as a rough and ready indicator for "strength". I then look at how quarter sawn they are and how consistent the grain pattern is.
The latest lot ranged from 4 to 16 growth rings (in the same width of 8mm). Here they are:
I guess my question is whether this is a good rough & ready way to select which blanks to use. Or do other people use other ways?
PostPosted: Wed Sep 25, 2024 5:12 pm
Last Name: Gramann
City: Fredericksburg
State: VA
Zip/Postal Code: 22408
I don’t worry about the growth rings. If my brace stock isn’t already split, I split it to find the runout. I do all of my cutting and shaping of the gluing surface parallel to the split so that the brace has no runout. After the braces are glued to the plates, I cut the height down and shape them to get the strength I want, testing by flexing and tapping as I go.
A brace with runout will not be a strong as one without and will be more likely to break, sometimes in places that are very inconvenient.
These users thanked the author bobgramann for the post (total 2): rbuddy (Thu Sep 26, 2024 11:52 am) • Kbore (Wed Sep 25, 2024 6:08 pm)
PostPosted: Thu Sep 26, 2024 3:20 am
Online
I take 1/4 sawn blanks of the same dimensions and drop them on the bench, grade them by the "ping" or vibrational frequency as they hit the bench.
These users thanked the author Colin North for the post: Kbore (Thu Sep 26, 2024 12:49 pm)
PostPosted: Thu Sep 26, 2024 9:52 am
As bobgramann says, runout is the most important thing.
Grain count has nothing to do with stiffness. The Young's modulus along the grain (E-long), which largely determines the stiffness at a given dimension, depends mostly on the density of the wood, and also the ratio of earlywood to latewood. Hard late wood, the dark lines, adds stiffness, but it adds density faster, so the ratio of stiffness:weight of the final brace will be lower if the late wood lines are heavy. Low density wood needs to be left a bit bigger, but ends up weighing less at a given stiffness.
In use, bracing makes up only a small part, maybe 25%-30% of the total weight of the top, even though it accounts for most of the stiffness. Saving 5% of the brace weight by using low density bracing means you've shaved off 5% of 30% of the weight of the top: a little more than 1% of the total.
That assumes that you're actually measuring the stiffness of the top/braces, and working toward an acceptable minimum. If you're working to dimension you're brace stiffness and mass is going to be a variable as the wood you're working with. Samples of Sitka spruce that I've measured can be as much as 20% above or below 'average' density and E-long, and the same goes for any other species.
In the end, though, it doesn't matter how 'good' the brace material is if it splits because of run out.
These users thanked the author Alan Carruth for the post (total 2): James Orr (Thu Sep 26, 2024 8:40 pm) • Kbore (Thu Sep 26, 2024 12:48 pm)
PostPosted: Thu Sep 26, 2024 5:19 pm
I agree with Bob and Alan. Runout is important. If the brace splits, nothing else matters.
What is your source for getting the brace blanks cut and thickness sanded like that?
PostPosted: Fri Sep 27, 2024 1:23 pm
I bought a fair bit of bracewood from a mill. They split the billets for the tops and when the billet gets too small, they sell it for bracing. The other bracewood wood I have came from Shane at High Mountain. They came in wedges and are from the outside of the tree, so it's mostly sapwood.
Brent
PostPosted: Sat Sep 28, 2024 10:00 pm
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
With spruce braces, density is a much better predictor of stiffness than grain count.
Sent from my SM-G950U1 using Tapatalk
These users thanked the author John Arnold for the post: Kbore (Sun Oct 20, 2024 9:23 pm)
PostPosted: Mon Sep 30, 2024 7:48 am
Last Name: Curran
City: Pietrasanta
State: Lucca
Country: Italy
The brace blanks come from Rivolta, one of the main tonewood suppliers in italy. My assumption was that they would come from split billets but that is just an assumption on my part. I'll check!
Thanks everyone else for the input. So to summarize, Young's modulus roughly correlates with density, which also (at least in the relatively small sample that I've looked out) also correlates with growth ring count. However, given the cube rule for stiffness, less dense blanks provide the same level of stiffness at a lighter weight, even if they need to left slightly higher.
However, the discussion on stiffness is much less important that runout. I'll split the blanks and see how much runout there is.
PostPosted: Mon Sep 30, 2024 8:13 am
Last Name: Curran
City: Pietrasanta
State: Lucca
Country: Italy
The first one i've split seems to be very straight. I take it i'm splitting it in the right direction?
PostPosted: Mon Sep 30, 2024 6:13 pm
OLF Sponsor
OLF Sponsor
First name: Brent
Last Name: Cole Sr
City: Craig
State: Alaska
Zip/Postal Code: 99921
Country: USofA
Well looky there, another rare bird that uses flat sawn bracewood product! :-) We at Alaska Specialty Woods, Inc.- alaskawoods.com , produce that cut of bracewood for Lowden Guitars in large quantity and always have it on hand for others as well. But ours is cut at 1"[24-25m] thickness And of course we have the VG cut of sawn and split face as well.
These users thanked the author Alaska Splty Woods for the post: bcombs510 (Mon Sep 30, 2024 7:44 pm)
PostPosted: Mon Sep 30, 2024 6:21 pm
OLF Sponsor
OLF Sponsor
First name: Brent
Last Name: Cole Sr
City: Craig
State: Alaska
Country: USofA
Honza, I was friends with Andrea. I met him at Luthier shows back early 2000's he came to visit me in Alaska in 2008 and selected a pallet of about 800 High grade sitka guitar tops that we shipped to him in Italy. He told me he was 3rd generation in that business. We have 3rd generation here at ASW too. But they are just playing in the sawsudust right now. But in aniother 8+ yrs they will be into the production too.
PostPosted: Mon Sep 30, 2024 10:16 pm
First name: Josh
Last Name: French
City: Houston
Honza wrote:
I can't speak to their brace wood, but I inquired with them to find out if their soundboards are sawn from split billets and they told me verbatim "I'm sorry but our sets are not sawn from split logs.". That might be okay for violins, but if I'm ordering top wood sight unseen for guitars that's a dealbreaker. For braces, you can at least split them yourself, and their prices are reasonable.
Instagram: @jfrenchluthier
PostPosted: Tue Oct 01, 2024 3:17 pm
Last Name: Curran
City: Pietrasanta
State: Lucca
Country: Italy
I like Rivolta. I live a couple of hours away so I can go and hand select stuff, no pressure to rush. Any they do lot's of thicknessing and planing for me as I don't have the machines at home. Nice people!
PostPosted: Tue Oct 01, 2024 3:29 pm
Last Name: Curran
City: Pietrasanta
State: Lucca
Country: Italy
Thanks for the reply. Though I can't quite tell if it's serious or not! Flatsawn braces????
The one in my picture is waiting to get cut down. I split it to check for runout. I take it I'm splitting it in the right direction? Your post has got me a bit confused....
PostPosted: Tue Oct 01, 2024 3:34 pm
Last Name: Curran
City: Pietrasanta
State: Lucca
Country: Italy
jfrench wrote:
OK, thanks for letting me know. That's interesting. Next time I go I'll find out exactly what the story is, split or just quarter sawn.
Luckily for me I live close by, so I get to hand pick, rather than sight unseen. Though I'm not exactly sure how to recognize runout, any hints?
PostPosted: Wed Oct 02, 2024 7:56 am
First name: Josh
Last Name: French
City: Houston
One easy way to tell is to take a picture on your phone with the flash enabled. If the reflection of the flash is even across the two boards, the runout is minimal. If the reflection skips at what would be the center seam, looking sort of like -_ then you've got runout at the center. If there's a long fluorescent or LED light above you that works too. Try it on some tops you already have and you should see what I mean right away.
These users thanked the author jfrench for the post (total 2): Kbore (Sun Oct 20, 2024 9:27 pm) • bcombs510 (Wed Oct 02, 2024 8:56 am)
PostPosted: Wed Oct 02, 2024 8:58 am
First name: Brad
Last Name: Combs
That's a great point, Josh. The light bar trick has been helpful for me. I actually demonstrated it during the monthly roundtable meeting back in July. Here is a direct link to the spot in the video where I show it - https://youtu.be/j70VsikbmaY?t=2293
Note for Tapatalk users: If it doesn't open at the right spot, fast forward to 38:00 minutes in.
Brad
These users thanked the author bcombs510 for the post: Kbore (Sun Oct 20, 2024 10:04 pm)
PostPosted: Wed Oct 02, 2024 10:00 am
First name: Josh
Last Name: French
City: Houston
Brad
Nice demonstration, Brad. Flipping the board is a good trick for those instances when the runout isn't a dealbreaker too.
These users thanked the author jfrench for the post (total 2): Kbore (Sun Oct 20, 2024 10:05 pm) • bcombs510 (Wed Oct 02, 2024 11:03 am)
PostPosted: Wed Oct 02, 2024 3:30 pm
Last Name: Curran
City: Pietrasanta
State: Lucca
Country: Italy
That looks like a great technique, thanks @jfrench
PostPosted: Thu Oct 03, 2024 1:16 am
Last Name: Arnold
City: Newport
Flipping end for end does not change the runout.
PostPosted: Sat Oct 19, 2024 3:04 am
Last Name: Curran
City: Pietrasanta
State: Lucca
Country: Italy
OK well this was interesting.
I split all the blanks, ten or so in total. Most were pretty terrible, I was quite surprised. Of the whole lot only two gave a length long enough (once ripped along the split) for X braces.
Thanks everyone for your input, this has been really useful!
Here's 3 of the set of 10. The top two I'm going to use as x braces, the bottom one is representative of the others. Pretty terrible runout!
These users thanked the author Honza for the post: Kbore (Sun Oct 20, 2024 10:06 pm)
Users browsing this forum: Colin North and 17 guests
