It is currently Fri Jul 18, 2025 2:05 am
PostPosted: Sat Dec 28, 2024 11:45 am
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
I was re-reading the excellent series of articles on Charles Fox written by Mark French for American Lutherie (Nos. 139-144), and ran across this hint that can save a person some money on drill bushings for jigs, fixtures and templates. Charles apparently uses ball bearings instead of actual drill bushings.
I like using 1/8” index pins in my guitar building, but have often complained (to those who will listen) about how expensive drill bushings are. So, I thought I would order some ball bearings and see if they would be suitable.
Here is a typical drill bushing that I use (cost: in the $8 range), alone and with a 1/8” drill bit in it:
Here is one of the ball bearings I ordered (cost: in the $1 range), alone and with a 1/8” drill bit in it:
These look and feel as if they will work just fine, and they are waaaaay less expensive than actual drill bushings. Thanks to Charles Fox for this small hint, along with all the other great contributions he has made to this endeavor!
These users thanked the author doncaparker for the post (total 7): Mark Fogleman (Thu Jan 02, 2025 5:03 pm) • Kbore (Sun Dec 29, 2024 8:05 pm) • Terence Kennedy (Sat Dec 28, 2024 6:35 pm) • ballbanjos (Sat Dec 28, 2024 4:46 pm) • SteveSmith (Sat Dec 28, 2024 3:49 pm) • Durero (Sat Dec 28, 2024 3:15 pm) • Colin North (Sat Dec 28, 2024 12:01 pm)
PostPosted: Sat Dec 28, 2024 12:02 pm
Excellent tip, thanks for bringing it to our attention.
These users thanked the author Colin North for the post: doncaparker (Sat Dec 28, 2024 12:40 pm)
PostPosted: Sat Dec 28, 2024 12:51 pm
Last Name: Parker
City: Charleston
My pleasure. I will offer one potentially adverse observation: There is a little more play in the inner diameter of the ball bearings than in the drill bushings, and the drill bushings are taller, so they are more capable of keeping the bit going straight while you drill. So, if you use these to drill holes, and the holes need to be super duper precise, the drill bushings are probably a better idea. But if a little play is OK for the task in question, the ball bearings look like they will be just fine, and definitely a lot easier on the wallet. And for something like mating with an indexing pin (instead of drilling holes), maybe a little play is a good thing.
These users thanked the author doncaparker for the post: Kbore (Sun Dec 29, 2024 8:06 pm)
PostPosted: Sat Dec 28, 2024 1:19 pm
Last Name: Gramann
City: Fredericksburg
State: VA
Zip/Postal Code: 22408
I make drill bushings out of hardwood on the drill press. I use them where I can’t fit the object to be drill into the drill press. When the fit gets sloppy, I drill another one.
PostPosted: Sat Dec 28, 2024 1:47 pm
City: U.P.
Here's something I really like when I need a precision hole in something I can't bring to the drill press. It also has a V-groove machined into the bottom for cross drilling a rod or cylinder.
https://www.amazon.com/Big-Gator-Tools-STD1000DGNP-V-Drill/dp/B0061FY004/ref=sr_1_9?
Thanks for the tip on shorter links Dennis!
Brian R, Wood Mechanic
N8ZED
These users thanked the author rbuddy for the post (total 4): Kbore (Sun Dec 29, 2024 8:05 pm) • bcombs510 (Sat Dec 28, 2024 5:05 pm) • ballbanjos (Sat Dec 28, 2024 4:46 pm) • SteveSmith (Sat Dec 28, 2024 3:49 pm)
PostPosted: Sat Dec 28, 2024 4:51 pm
Last Name: Kincheloe
Great idea!
Ball bearings are also useful for calibrating a CNC machine. Mill a plug that fits in the bearing hole, and a hole that the bearing fits into. If the plug is loose in the bearing but the bearing fits just right in the hole, you need more backlash compensation and smaller tool radius.
rbuddy: When copying ridiculously long links like that, you can generally delete everything after the question mark. It's just tracking info which tells amazon that you are the one who posted a link on this web site anytime one of us clicks it.
These users thanked the author DennisK for the post (total 5): Kbore (Sun Dec 29, 2024 8:06 pm) • bcombs510 (Sun Dec 29, 2024 10:19 am) • RNRoberts (Sun Dec 29, 2024 9:18 am) • banjopicks (Sun Dec 29, 2024 5:56 am) • rbuddy (Sat Dec 28, 2024 5:10 pm)
PostPosted: Sun Dec 29, 2024 9:50 am
I have stacked bearings to make a taller drill bushing. Easy to tape a group together on their outer surface, make them as tall as you need and still be money ahead.
jw ( o)===:::
These users thanked the author joe white for the post (total 2): doncaparker (Sun Dec 29, 2024 10:29 am) • bcombs510 (Sun Dec 29, 2024 10:19 am)
PostPosted: Sun Dec 29, 2024 8:07 pm
First name: Karl
Last Name: Borum
Zip/Postal Code: 63303
Great tip, thanks!
Measure Twice,
Karl Borum
