It is currently Fri May 30, 2025 1:34 am
 Post subject: Neck bolts
PostPosted: Fri Mar 14, 2025 5:30 pm
First name: David
City: Napa
Zip/Postal Code: 94558
Would you consider a Stainless steel bolt good or do you think it would not be strong enough?
I've been utilizing two 1/4-20 for Acoustic guitar necks and two 8-32 or one 1/4 x 20 for ukulele necks.
Thoughts?
I don't like the look of the dull black hardened steel bolts. hmmmm
 Post subject: Re: Neck bolts
PostPosted: Fri Mar 14, 2025 6:17 pm
Stainless is fine. I’ve been using them for years with brass inserts or barrel nuts. Stainless bolts with stainless nuts can gall but not likely to be an issue with the low torques used on guitars.
PostPosted: Fri Mar 14, 2025 8:23 pm
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
I have used one 10-32 bolt on a few guitars. It is much stronger than the wood.
Sent from my SM-G950U1 using Tapatalk
PostPosted: Fri Mar 14, 2025 9:12 pm
There’s really not that much pressure on the bolts. I think it’s a good idea to use bolts that are softer than the inserts. I just use Home Depot ones.
PostPosted: Sat Mar 15, 2025 4:29 pm
First name: Mark
Last Name: McLean
City: Sydney
State: New South Wales
Zip/Postal Code: 2145
I agree. You don’t need great strength in this joint.
PostPosted: Sat Mar 15, 2025 6:33 pm
Use a lube like SWAK on stainless steel to prevent galling.
PostPosted: Sat Mar 22, 2025 12:04 am
First name: peter
Last Name: havriluk
City: granby
State: ct
Zip/Postal Code: 06035
Thoughts?
'Stainless' or 'hardened steel'....either alloy will work just fine. Folks mistakenly assume that stainless, not being prone to rust, is stronger than non-stainless. Very not so. Stainless can be quite weak, it gets hard to cut because of its property of work hardening when you cut it. That does not make it strong. Just about any 1/4-20 steel bolt is serious overkill, you could tow your car with two of these. I think guitar factories latched onto them because they were plentiful and cheap.
Peter Havriluk
PostPosted: Sat Mar 22, 2025 6:31 am
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
I don’t know about factories, but for individual builders, I think the wide availability and low cost of 1/4-20 hardware are two large reasons why we use it. And they do work great, of course. Smaller bolts and inserts work great, too, but they are not as readily available. If weight or size are concerns, and you can get the smaller hardware, that’s the way to go.
PostPosted: Sat Mar 22, 2025 7:17 am
City: U.P.
A lot of folks worry about threaded inserts pulling out of the neck. Smaller inserts would likely pull out of end grain more easily than larger ones. Fastener strength really isn't an issue in the application. The large head diameter of the 1/4-20 furniture bolts make them pretty close to perfect for me.
Brian R, Wood Mechanic
N8ZED
Users browsing this forum: No registered users and 41 guests
