It is currently Sun Sep 14, 2025 9:59 pm
PostPosted: Wed Apr 09, 2025 6:24 pm
There’s nothing that I know of that is wrong with it. The blade is relatively new. It was sitting unused in my garage for many years and the table is rusted to heck, but I seem to recall it was doing this when I renovated it out of action. It starts fine, but when I try to cut with it, the blade bogs down and sometimes even to s stop.
Any ideas?
How hard is it to replace a bandsaw motor? KMS tools had a 2hp for 80$…
These users thanked the author meddlingfool for the post: Pat Foster (Wed Apr 09, 2025 7:08 pm)
PostPosted: Wed Apr 09, 2025 7:12 pm
You might check your line voltage. When I lived in an old neighborhood, it would vary 15%. I don't know how that would affect a BS, but it wreaked havoc on my work in the darkroom.
These users thanked the author Pat Foster for the post: Kbore (Sat Apr 12, 2025 3:28 pm)
PostPosted: Wed Apr 09, 2025 7:14 pm
Last Name: Ensor
City: Springfield
State: Missouri
I would start by looking at the motor. May be the bearings are starting to seize. If so, the motor may be struggling to turn and the extra resistance of cutting is too much for it. Replacing a motor isn’t a big deal as long as you’re mechanically inclined. Replacing motor bearings is also fairly easy if they aren’t stuck to the shaft or housing.
http://elevatelutherie.com
http://ensorguitars.com
PostPosted: Wed Apr 09, 2025 7:50 pm
Online
Last Name: Gramann
City: Fredericksburg
State: VA
Zip/Postal Code: 22408
All of the above plus check the bearings on the wheels. Almost every city has a bearing shop where you take the old bearing, they measure it, and give you a new one that turns.
I let the smoke out of a motor on a bandsaw I had long ago. Replacing the motor was simply moving the drive pulley to the new motor, bolting it in, and wiring it up. The motor mounts for this type of motor are pretty standard such that a motor fits many different machines. If you put too big of a motor on a bandsaw frame designed for less, the bigger motor may have the ability to distort the frame when the cut gets hard.
Along Pat’s line of reasoning above, make sure you’re not using an inadequate extension cord.
PostPosted: Wed Apr 09, 2025 8:02 pm
City: Tyler
After running it, feel the temp of the motor. Should be nothing more than warm.
PostPosted: Thu Apr 10, 2025 12:30 am
Thank you I will check all these things…
PostPosted: Thu Apr 10, 2025 4:07 am
First name: Roy
Last Name: Machin
City: Mexborough
State: South Yorkshire
Zip/Postal Code: S64 0HW
Country: United Kingdom
If the saw has an induction motor I would check the run capacitor. Mine had the same problem as yours and a replacement capacitor cured it, likewise with my bench grinder and disk sander.
If you can`t check it with a meter I suggest that you replace it anyway, they`re cheap from Amazon.
PostPosted: Thu Apr 10, 2025 8:43 am
First name: Aaron
Last Name: Hix
City: Chatsworth
State: Georgia
Zip/Postal Code: 30705
Bearings getting hot and sticking, or capacitors.
Guitar Maker and Purveyor of the World's Finest Tonewoods
http://www.aaronhixguitars.com/
http://stores.ebay.com/A-Hix-Tonewood-a ... r-Supplies
PostPosted: Thu Apr 10, 2025 9:22 am
First name: Leonard
Last Name: Duke
City: Kalamazoo
Zip/Postal Code: 49001
Derail the drive belt at one end. Turn the motor by hand. Tension the blade and turn the bandsaw by hand. Don't get distracted and cut yourself. After these tests you might know if the problem is the motor or the saw.
With the blade off, check all the saw bearings for slop or roughness.
Is the blade path through the guides a nice straight line?
These users thanked the author philosofriend for the post: Kbore (Sat Apr 12, 2025 3:30 pm)
PostPosted: Thu Apr 10, 2025 5:10 pm
First name: Mark
Last Name: McLean
City: Sydney
State: New South Wales
Zip/Postal Code: 2145
When mine started doing that it was the drive belt tension that was to blame. It was slack and slipping when the blade came under resistance. Tightening it up immediately improved things.
PostPosted: Thu Apr 10, 2025 5:53 pm
I’ll look into that as well, thanks…
PostPosted: Sat Apr 12, 2025 1:56 pm
First name: Mark
City: Concord
Don't ask me how I know this but check the orientation of the teeth. They should be facing down. It's easy to mount it upside down.
PostPosted: Sat Apr 12, 2025 3:49 pm
I’m happy to that at least that much I got right…:)
These users thanked the author meddlingfool for the post: Kbore (Mon Apr 14, 2025 8:16 am)
PostPosted: Fri Jul 18, 2025 4:22 pm
Last Name: Hemsey
City: Seattle
Zip/Postal Code: 98104
Could be the motor getting weak, but also check blade tension and alignment first—sometimes it’s not the motor. Swapping motors isn’t too bad if it fits, and $80 for a 2HP sounds like a solid deal. If you want something new, I get my parts off of Bandsawparts.com
These users thanked the author Hemessy for the post: meddlingfool (Fri Jul 18, 2025 4:55 pm)
PostPosted: Sat Jul 19, 2025 9:14 am
Ditto! Mine did that and I struggled for a couple of months, changing blades, adjusting guides, etc. I even priced new saws. Tightened the belt and it cuts great.
These users thanked the author guitarjtb for the post: Kbore (Sat Jul 19, 2025 6:56 pm)
PostPosted: Tue Jul 22, 2025 5:08 pm
Last Name: Hemsey
City: Seattle
I am sorry for reigniting this post again. Apparently, this was made last 2008! New to the forum.
PostPosted: Wed Jul 23, 2025 12:06 am
Nope, 2008 was my join date, the thread is from April 2025…
PostPosted: Wed Jul 23, 2025 3:54 am
First name: Roy
Last Name: Machin
City: Mexborough
Ed, did you find the fault on your bandsaw?
PostPosted: Wed Jul 23, 2025 11:49 am
Nope. I got my Laguna 1412 back once so it can go back to the back burner. I have three other bandsaws, lol…
PostPosted: Thu Jul 24, 2025 12:16 am
First name: Tomás
Last Name: Mac Giolla Ghunna
Country: Éire
Flat tires/tyres will compress the set on regular blades and cause such issues...
That goes for both, having the teeth tracking over the edge of the wheel, with wider blades what's possible to do so,
and for narrower blades, this will happen a whole lot quicker.
Just about the only mention of such, is in an old Centauro manual for the SP, quoted below.
" MAIN TROUBLE AND RELATIVE REMEDIES "
The blade moves very far back when it receives the cutting force
- Insufficient flywheel seal convexity, notify the technical service of the area dealer.
Look into things a little further, take the little Inca or Kity saws for example, which some folks seem to get decent results from...
though I do wonder how much life they get from their blades...
The only explanation for such I can see, being a phenomenon called anticlastic curvature, something likely well known for many here, but not by name.
i.e basically there will be a raised profile on the edges of anything flat, when its bent around something, so acts something like a camber.
Whether that has worn or compressed, would be my suspicion,
So my guess is you've bought some tires without any cambered profile, urethane ones perhaps?...
and BTW, before anyone mentions Italian saws, show me the money! ... i.e a decent lifespan from a regular narrow blade, with such tyre/tire profile
w/blade what's tracked in the centre of the wheel or thereabouts,
or show me beam strength from a regular blade whilst ripping or resawing, without any huge HP motor & ceramic thrust guides involved.
Seemingly it's mostly European videos where you will find regular blades used, so perhaps one could study the Felder saws, unboxing/review videos mainly
Those Felder tires having seemingly less camber than Centauro's (which is very little)
That will provide a good study on beam strength, for one who's bandsaw is "bogging down"
That's my guess.
Cheerio
Tom
PostPosted: Thu Jul 24, 2025 5:06 pm
Ed, if you have to replace the motor -- then really look into a VFD and an old 3 phase motor. You can get fabulous 3phase motors on eBay for cheap and the VFD gives you a soft start plus control of the RPM. Feel free to give me a call if you want help on that. If you are so inclined, refurbishing "Old American Iron" can get you some incredible machines and learning how to setup a VFD opens up the door to all that great 3phase equipment.
PostPosted: Thu Jul 24, 2025 5:22 pm
I thinks that’s above the needs for this saw, which I may never even bother to fix. It’s saw number four and sat unused in the garage for years…
PostPosted: Fri Aug 01, 2025 5:13 pm
Last Name: Hemsey
City: Seattle
Oh, wow! Selective reading, I guess. I am sorry. I got a Laguna 1412 too! Just like you I have 3 other bandsaw too!
PostPosted: Fri Aug 01, 2025 7:41 pm
And room for more!
Users browsing this forum: bobgramann, Dmaxwell and 62 guests
