It is currently Sat Jul 19, 2025 10:06 pm
PostPosted: Mon May 19, 2025 3:01 am
These are the most affordable selections mill direct in my area. I happen to have enough cedar on hand to build half another house, with a fair bit of fir in the mix as well.
When I watch YouTube videos of people making dramatic tablesaw outfeed tables they always use either hard maple or Home Depot ‘construction lumber’ doubled up and planed square for legs and stringers.
I want to make a dramatic outfeed table just like the folks on YouTube.
Is there a reason to not use materials on hand?
I worry about cedar being saggy…
PostPosted: Mon May 19, 2025 3:31 am
Fir, it's stronger, denser, stiffer and harder.
My $0.02.
PostPosted: Mon May 19, 2025 5:45 am
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
Construction lumber is frequently stamped as SPF, which means it could be spruce, pine, or fir. So, if you have easy access to lots of fir, you should be in good shape to build bench parts with it.
I don’t know enough about the different types of cedar to comment on whether it is a good choice.
PostPosted: Mon May 19, 2025 7:53 am
Last Name: Gramann
City: Fredericksburg
State: VA
Zip/Postal Code: 22408
Cedar in 4x4 dimensions is pretty solid. I wouldn't hesitate to use it. I’ve used it for deck posts and deck railings.
PostPosted: Mon May 19, 2025 8:51 am
Either one. Like Bob back in my carpenter days we made plenty of decks and porches from cedar. Plenty of fir used for framing. I did a remodel in N California once and the house was framed with redwood.
PostPosted: Mon May 19, 2025 10:31 am
Online
First name: Mark
Last Name: McLean
City: Sydney
State: New South Wales
Zip/Postal Code: 2145
Didn’t they once build railway bridges with cedar and redwood? Use what you have on hand, and laminate two or more planks together to make it stronger if you need to. And it will smell great - always a bonus.
PostPosted: Mon May 19, 2025 11:46 am
My brother built a workbench out of fir many years ago (20+) and it's held up fine.
PostPosted: Mon May 19, 2025 1:10 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I'm not sure what you are planning to put on this dramatic outfeed table that would be enough strain to make cedar legs a bad option. The dimensions of the legs will be the bigger concern when it comes to strength. Thin, narrow cedar legs might be iffy but then, so would think Maple legs. Utility pols seem to hold up fairly well, deck posts too. I think your table will be fine. . .
Bryan Bear PMoMC
PostPosted: Mon May 19, 2025 2:22 pm
I’m not sure either, lol, so I want to plan for the best. I guess I’m also asking about dimensional stability with RH swings. The bench I have in mind will not be in the RH control area, but I want it to be built flat and stay flat permanently as a flat reference surface.
PostPosted: Mon May 19, 2025 4:38 pm
Last Name: Gramann
State: VA
For structure, appropriately dimensioned cedar or fir will do fine. When I’m building a jig or a surface that I absolutely do not want vary dimensionally, I laminate several layers of 3/4” birch ply and then cut and machine to final dimensions. It’s relatively expensive, but it works well.
PostPosted: Mon May 19, 2025 4:57 pm
That’s the plan. I have some solid core doors that will be the basis of the bench top, layered with either a Formica add on or pre finished plywood. I guess the question is, is there any reason not to use what I already have piles of or can get cheaply locally, cedar being what I got, fir being what I can get…
PostPosted: Mon May 19, 2025 5:36 pm
Last Name: Gramann
State: VA
I can’t think of a good excuse to buy more wood unless it will make you feel better using it if it costs more.
Personally, I am realizing that I won’t be doing this forever and I need to use existing stock. It’s hard to bypass the temptation to buy more wood, but I’m trying hard.
PostPosted: Mon May 19, 2025 5:44 pm
I just don’t want to build a big complex infrastructure piece to find out I shot myself in the foot using inappropriate materials. Guitars I know, everything else…not so much.
PostPosted: Mon May 19, 2025 5:54 pm
Yep ;)
PostPosted: Mon May 19, 2025 10:36 pm
First name: Carl
Last Name: Dickinson
City: Forest Ranch
Zip/Postal Code: 95942
Use the cedar. I'd be more concerned that the door tops would stay flat.
Sent from my moto g stylus (2021) using Tapatalk
PostPosted: Mon May 19, 2025 10:40 pm
Also something I’m trying to suss…
PostPosted: Mon May 19, 2025 11:59 pm
My first bench had a fir base. I inherited it—it was aged when I got it, and perfectly stable 20 years later. The only thing to watch out for is that fir can splinter easily if you catch the edge the right way. Just make sure you round the edges over well and don’t have any little fibers wanting to lift up.
The top of my current bench is actually tight, vertical grain fir. It’s unconventional, but beautiful. VG fir is one of my favorite timbers. I can’t get enough of the stuff.
PostPosted: Tue May 20, 2025 12:40 am
You’re not helping my use what you got, lol…
PostPosted: Tue May 20, 2025 6:12 am
Last Name: Parker
City: Charleston
If you are concerned about the working surface staying flat through humidity changes, how about building a torsion box for the working surface?
PostPosted: Tue May 20, 2025 11:58 am
Not too hard to make I expect…
Users browsing this forum: Mark Mc and 21 guests
