It is currently Thu Jul 17, 2025 4:24 am
 Post subject: Inlay Glue
PostPosted: Wed Jun 11, 2025 9:20 pm
First name: Jon
Last Name: Snider
City: Colorado Springs
State: Colorado
For a dark Ebony headstock veneer, do more folks prefer using CA glue with Ebony sawdust, or black CA glue, or black tinted epoxy?
Thanks.
 Post subject: Re: Inlay Glue
PostPosted: Wed Jun 11, 2025 10:07 pm
First name: David
City: Napa
Zip/Postal Code: 94558
I like ebony dust with ca. But also depends on which one is closer. I had to sand up miles of ebony so I saved bout 2 gallons of the dust lol
PostPosted: Wed Jun 11, 2025 11:50 pm
First name: Karl
Last Name: Borum
Zip/Postal Code: 63303
I prefer Epoxy tinted with wood dust because for me it sands down easier than CA, and is easier to scrape and to file.
I've also tinted the epoxy with TransTint but prefer wood dust.
Measure Twice,
Karl Borum
PostPosted: Thu Jun 12, 2025 9:18 am
Black epoxy if there are areas where I want the black to show. Black CA when I just want to glue in a well-fitted inlay.
PostPosted: Thu Jun 12, 2025 11:23 am
Ebony dust rubbed into the gaps, then thin CA.
I'd recommend making the dust with a clean medium file rather than sandpaper. It will avoid the bits of sandpaper grit mixed in with your ebony dust that inevitably end up where they would be most visible.
Also, a quick wash of the CA across the entire face of all the ebony can help avoid your fill showing up by looking slightly different from the surrounding ebony at certain angles due to a difference in it's reflectance.
These users thanked the author RNRoberts for the post (total 3): Colin North (Fri Jun 13, 2025 9:39 am) • Robbie_McD (Fri Jun 13, 2025 8:34 am) • Kbore (Thu Jun 12, 2025 3:31 pm)
PostPosted: Thu Jun 12, 2025 9:23 pm
Ebony dust with thin CA here. I stick a drum sander with 120G in the drill press and hold a folded sheet of typing paper next to it as I feed in some scrap Ebony offcuts. The paper catches the dust and then I slide it into old film canisters for storage.
These users thanked the author Terence Kennedy for the post: Kbore (Fri Jun 13, 2025 2:11 pm)
PostPosted: Sun Jun 15, 2025 3:24 pm
I use epoxy and powdered black dye.
These users thanked the author Brad Goodman for the post: Kbore (Sun Jun 15, 2025 4:04 pm)
