It is currently Sun Aug 10, 2025 11:15 pm
PostPosted: Sun May 07, 2006 10:17 am
I am after 12 string spacing .
I'm thinking of a 1 7/8 " at the nut . and 2 3/8 " at the saddle .
What space do you leave between the paired strings at the nut.........and the bridge ?
I don't mean between E,A ,D etc. I mean the small space between the unisons
CRAIG LAWRENCE of AUSTRALIA
PostPosted: Sun May 07, 2006 11:01 am
For the one I am building now...
1 7/8th nut
0.07 between each in a pair
0.19 between pairs
This matches what Taylor Guitars uses
PostPosted: Sun May 07, 2006 11:55 am
[QUOTE=KiwiCraig]
the bridge ?
unisons[/QUOTE]
Gidday Craig,
A very timely question..will have a 12 string in the starters blocks here
shortly. Post up some progress pics when you can.
Cheers Martin
PostPosted: Sun May 07, 2006 12:08 pm
O. K. Martin !
On your marks,
Get set ! ..........
Mine is going to be a little radical . I'll keep you posted.
Thanks Andy . Have you got the spacing for the nut AND the bridge ?
Cheers KiwiCraig
PostPosted: Sun May 07, 2006 8:06 pm
[QUOTE=KiwiCraig]
O. K. Martin !
On your marks,
Cheers KiwiCraig[/QUOTE]
Im out of the blocks......Sitka top glued up today.
PostPosted: Mon May 08, 2006 12:26 am
1 7/8 nut and 2 3/8 saddle is going to be pretty tight on a 12 string. My 12 strings are 2" nut 2 1/2" saddle.
PostPosted: Mon May 08, 2006 2:19 am
My last 12 string client wanted it to feel "pretty much like his 6 string". So I gave it a try. I went down to 1 13/16" and suprisingly it played great. Not much finger picking, but that won't happen on a 12 string unless you are Leo. It's very easy to grab the right pair when fretting.
I'd say go for the 1 7/8". Should feel pretty nice.
PostPosted: Tue May 09, 2006 9:44 am
bump
