It is currently Mon Aug 11, 2025 9:54 am
PostPosted: Tue May 09, 2006 5:17 pm
Terry your solution is far more sophisticated than mine, I just use a 90 degree fence on my drill press, I apply my dots to the fingerboard before I attach it to the neck, I have also found that for some reason (I guess they are harder) metal working bits seem to have less flex.
PostPosted: Tue May 09, 2006 7:12 pm
I eyeball it, and it usually goes fine. I tend to use metalworking bits because I've found them to be more accurate and less flexible (twist pattern is different, for one thing).
Your method will only really work with a compound radius board, I'd think; single radius board edges get thinner as you move up the neck.
PostPosted: Tue May 09, 2006 10:57 pm
I found the perfect solution with a student last year - all his side dots were dead on except one - it really bothered him so we discussed getting it out - no easy task. The solution - we drilled (routed) it out in the drill press with a 1/16 inch router bit (using a fence). So now every time I do side dots, I use the router bit first to set the hole - it only has about 3/16 of cutting length and is solid carbide, 1/4 inch shank - lee valley - and dosent flex at all, so you get a dead on pilot hole for the 2mm drill bit. Works every time.
PostPosted: Wed May 10, 2006 12:16 am
I find my system to be flawless and absolutely guarenteed, I don't put any in at all, that way they are never in the wrong place.
PostPosted: Wed May 10, 2006 1:09 am
I do my FB before attaching to the neck, also. I sandwich the FB between two squared strips of wood so that it sits level and square on the drill press table, then use a fence to make sure all holes are drilled the same. Using a brad point bit, I haven't had any "wandering" problems. I use 3/32" MOP dots.
PostPosted: Wed May 10, 2006 5:06 am
i used to do them by hand,
but i recently bought a 5 axis cnc just for doing this job.
PostPosted: Wed May 10, 2006 5:57 am
[QUOTE=PaddyD] i used to do them by hand,
What an awesome reason to buy a new tool! I'm gonna try that one with the wife!!
PostPosted: Wed May 10, 2006 6:13 am
Just to clarify,
i am joking
i dont think i could really justify a 300k dot installer.......
but a bottle opener.... now theres an idea!
paddy
PostPosted: Wed May 10, 2006 7:32 am
I sometimes do as Terry, but usually just mark the spot with a pencil, visually in the center of the frets. Then I lay a piece of celluloid binding on the workbench beside the fretboard, and drill the hole at the mark. I get a perfect .060" margin everytime, moving the binding to a new spot each time so it doesn't wearlower.
Nice jig Terry. Won't the hole eventually enlarge?
PostPosted: Wed May 10, 2006 7:57 am
I reckon that will work Colin
PostPosted: Wed May 10, 2006 1:57 pm
Great jig Terry, thanks for the great tips guys!
PostPosted: Thu May 11, 2006 12:44 pm
On the last guitar I finished (I'll post pics soon), I forgot to put the side dots in. I don't put markers on the face of the fretboard as a rule (I'd put 'em in if a customer really wanted them, but I'd try to talk them out of it). So, this guitar, which I have no plans to sell, has no markers. I'm thrilled with this. It is just the push I needed to break the habit of looking at the neck while playing - a bad habit, indeed, IMHO.
Todd Rose
Ithaca, NY
PostPosted: Thu May 11, 2006 7:26 pm
I've pondered doing no dots, or fewer dots, simply because I play with a capo quite a bit, which means they're sometimes more of a chore than a blessing. On the other hand, they're one of the very few decorative touches I put on my necks, and I do like the shiny pearly abalone-y-ness...
PostPosted: Thu May 11, 2006 9:50 pm
Last Name: Bordeaux
City: Massena
State: New York
Zip/Postal Code: 13662
Terry,
Do you center punch the holes prior to drilling?
Why not use your type of jig prior to mounting the FB from the back,(flat) side.
I use a 90 degree fence with a router bit and it's quite accurate.
Paul Bordeaux
http://www.bordeauxinlay.com
PostPosted: Fri May 12, 2006 4:40 am
Great thread guys, great tips! Thanks!
