It is currently Tue Aug 12, 2025 4:26 am
PostPosted: Thu Jun 01, 2006 11:41 pm
Last Name: Beaver
City: Lake Forest
I tend to make my fingerboards a little on the wide side having fat fingers, 13/16" at the nut. I was wondering what radius you prefer for the wider boards?
Joe Beaver
Maker of Sawdust
PostPosted: Thu Jun 01, 2006 11:57 pm
Joe Im going to poke a little fun at you, but 13/16 wide at the nut???? I would not consider that wide at all I know you ment 1 13/16". Actually this is a very common width Finger style player offen prefer this width or even wider. To answer your question I still use 16" radius on this width. I have one client that has a bad joint in his index finger. It is permenatly bent. for him I use a 14" radius.MichaelP38870.373900463
PostPosted: Fri Jun 02, 2006 12:15 am
Joe,I always use 16" radius. Some use the 20" but thats a little bit flat for my taste. 1 3/4 width at the nut.
PostPosted: Fri Jun 02, 2006 12:16 am
If you go to your local vintage guitar shop, and play an old Fender, You will see the extreme example of a small radius. If I'm not mistaken, they were 6 or 7 inches.They are actually quite comfortable to play, especially if you use a lot of barre chords. The problem lies in using string bending techniques. If you bend strings on a fretboard with a small radius, the string will "fret out" at the next fret and cause a sudden change in pitch. Most guitarists today like their fretboard radius between 12" and 18", or a 10"-18" compound. If you stay within these parameters, you'll be allright.
PostPosted: Fri Jun 02, 2006 5:50 am
[QUOTE=A Peebels]...old Fender,...If I'm not mistaken, they were 6 or 7 inches. [/QUOTE]
Generally, they were 7.25".
PostPosted: Fri Jun 02, 2006 6:17 am
I do a compound radius of 10" moving to 14" on my electrics.
And 12" moving to 16" on my acoustics.
PostPosted: Fri Jun 02, 2006 2:21 pm
Last Name: Beaver
City: Lake Forest
Good info guys. I currently have 14", 16" & 20" wood radius blocks but was thinking about getting a 18" long aluminium radius beam from stew mac. I can't afford to buy more than one now. I was undecided as to what radius to get. I'm thinking after reading your post that the 16" may be the one for me to start with. Thanks for the great feedback. I'll check back later.
Joe Beaver
Maker of Sawdust
PostPosted: Fri Jun 02, 2006 2:23 pm
Last Name: Beaver
City: Lake Forest
[QUOTE=Brock Poling]
And 12" moving to 16" on my acoustics.[/QUOTE]
Brock,
How do you do that? Start with 16" overall then sand down to the smaller radius?
Joe Beaver
Maker of Sawdust
PostPosted: Fri Jun 02, 2006 2:29 pm
Last Name: Beaver
City: Lake Forest
[QUOTE=MichaelP] 13/16 wide at the nut???? I would not consider that wide at all [/QUOTE]
You could be right. 13/16" is a little tight. I might try the extra inch.    ... but it sure was nice getting all those fingerboards out of one piece of wood
Joe Beaver
Maker of Sawdust
PostPosted: Fri Jun 02, 2006 3:59 pm
[QUOTE=Joe Beaver] [QUOTE=Brock Poling]
Brock,
How do you do that? Start with 16" overall then sand down to the smaller radius?[/QUOTE]
I don't. I have Craig Holden's jig. I just set it for 12" at the nut and 16" at the saddle location then profile the radius with a router. It takes less than 5 minutes and it produces perfect results.
