It is currently Tue Aug 12, 2025 8:48 am
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
PostPosted: Thu Jun 01, 2006 10:42 am
i can only agree with those who have opined that the allied machine is overkill. perhaps worth it in a school or a production shop but for the hobbyist or the small scale custom builder it is over the top.
use your money for something you need...
PostPosted: Sat Jun 03, 2006 2:22 pm
Hey Mike , just to reply to my follow up question, the sides bent perfect as a matter a fact i took a measurement from the top of the bulbs to the top of my form (at lower .... height 4-7/8) (the upper 3-3/8) the temp rose farely fast. as soon as it reached bending temp .......it was on like a pot of neck bones. . . the sides came out looking good
the side in mold
thanks Mike for the comment.
PostPosted: Sat Jun 03, 2006 4:00 pm
Really nice bender Matt, didn't have the courage to build me that upper part when i built mine, didn't have enough info and realize now that i should have asked!
PostPosted: Sat Jun 03, 2006 4:42 pm
Or you can go this route:
I use a mold that I made from MDF with a blanket that has a thermocouple, which is tied into a temp controller (mounted in that artsy looking box). The darkroom timer is used to time the heat cycles. I ordered the plans and the blanket from Tom (aka mandomaniac over at the other forum) and assembled the setup myself. Total cost, including the plans, blanket, controller, timer, and a solid-state relay with heat sink, was about $200. Works amazingly well. More recently I added spring steel slats and a reverse mold (which fits over the slatted sides) in order to reduce the chance of the sides developing "ripples" when bending.
Best,
MichaelMichael McBroom38872.0747569444
Live to Play, Play to Live
