It is currently Wed Apr 30, 2025 11:53 pm
PostPosted: Wed Jun 07, 2006 11:04 am
I was looking for a good vise to hold the guitar while working on it and I
need to compliment one of our own. I have always struggled to hold the
guitar etc.
Well I stumbled on Sylvans guitar vise...it is up in the online resources
section, not the jig section above.
How simple and awesome. 2 pipe clamps some flanges and your done!!!
I highly recommend it to anyone who is struggling to hold a guitar.
Here is a direction link
Sylvans
Awesome Guitar Holder/vise
Bravo Sylvan Wells!!!azimmer138875.837025463
PostPosted: Wed Jun 07, 2006 11:20 am
That is awesome, I'm building one ASAP, thanks for the heads-up.
Greg
Gwaltney Guitars
PostPosted: Wed Jun 07, 2006 11:21 am
Ditto, I'm using one just like it
PostPosted: Wed Jun 07, 2006 11:29 am
Yeah,This is one of the easiest jigs to make and
it works great.I use mine all the time.
PostPosted: Wed Jun 07, 2006 11:34 am
First name: Coe
Last Name: Franklin
City: Decatur
Hmm...
Should the cauls be radiused so as to not pop any braces loose? Looks like something I should be using.
Thanks, Gang
PostPosted: Wed Jun 07, 2006 12:48 pm
Sylvan is chock full of great ideas. He once offerd a class of "jig making" here on OLF. I don't recall exactly what happened but i was the only attendee. It was a Fabulous Class! I learned so much from Sylvan...and continue to learn, just looking back at my photos and notes. Guys...get together and see if you can't convince him to hold another class...you will be amazed!
PostPosted: Wed Jun 07, 2006 1:45 pm
[QUOTE=Cocephus] Hmm...
Thanks, Gang[/QUOTE]
Coe, The plywood with cork lining is only 1/4 inch so it bends around the body shape.I never had any problems with poping braces.
PostPosted: Wed Jun 07, 2006 2:00 pm
Mine has the same blue cushiony material i lay my guitar on when working on my bench, it's also 1/4" thick and works really well.
PostPosted: Wed Jun 07, 2006 2:17 pm
First name: Mark
Last Name: Tripp
City: Olympia
State: Washington
Zip/Postal Code: 98506
Yup! Found this a while back and built two of 'em - used 1/4" masonite lined with 1/4" cork - nice and flexible. Don't think I have more than $20 into both of them, and they get used all the time.
Great idea!
-MarkMark Tripp38875.9709375
Pullman, WA
trippguitars.com
OR
Find me on Facebook
PostPosted: Wed Jun 07, 2006 2:20 pm
Yep, I've got one too. It really comes in handy when sanding the sides.
PostPosted: Wed Jun 07, 2006 2:42 pm
I built one not long ago, using three pipe flanges, so I can equally grip a guitar across its width or along its length, with 1/4" ply and carpet. Works really well.
PostPosted: Thu Jun 08, 2006 12:51 am
I really appreciate everyone's praise for the holding jig. I just want to
mention however, that it was originally not my idea, that I got it from
someone else many years ago. Probably from the Guild of American Luthier's
magazine sometime in the eighties. But, it does work great!!
Sylvan
http://www.wellsguitars.com
PostPosted: Thu Jun 08, 2006 1:05 am
First name: Rich
Last Name: Barbera
City: Bay Area
Yup... What a great, yet simple device. I put on a couple of mounts at different locations in my small workspace. The only difference w/ mine is that I downsized the pipe clamp size...to the next size below what Sylvan used...so it's not quite as massive.
Thanks Sylvan!
PostPosted: Thu Jun 08, 2006 1:09 am
I just bought pipe clamps like this at Harbor Freight to make one of these, they were on sale for about $4 each I think, for 3/4" pipe clamps.
PostPosted: Thu Jun 08, 2006 5:34 am
just a word of caution to those using these for the first time -- it is easy to overtighten the pipe clamp and crack a side... be gentle!!!
PostPosted: Thu Jun 08, 2006 8:24 am
First name: Nelson
Last Name: Palen
I use a setup similar for archtops but am very carefull to make it so the grandkids can't come along and see how tight they can get the clamps.
PostPosted: Fri Jun 09, 2006 4:42 am
I just made one too! Thanks for the idea - cheap and effective - just like I like em!
Charliewood
PostPosted: Sat Jun 10, 2006 4:45 am
Last Name: Beaver
City: Lake Forest
I like it alot! Thanks Andy
Joe Beaver
Maker of Sawdust
PostPosted: Sun Jun 11, 2006 11:19 am
There was an article that spanned about 3 issues in the GAL magazine* on jigs and fixtures than none other than “Mr. fixture” himself Charles Fox. It has loads of great stuff in there and I am pretty sure that is what inspired my take on the guitar holding vice. I think he used Veneer Press screws, to apply clamping force but I had the pipe clamps hanging around, so I used those. Hopefully from the 2 pictures it should be fairly self evident.
In this shot I just did a coat of pore filler the guitar and needs a little cleanup before I do the second coat. I have some fairly rigid “foam” in vice that grabs the guitar pretty well and makes-up for discrepancies in the radius of the MDF clamping face. Carpet would probably work too.
Here is shot looking up from the bottom. You can see my sling. This prevents the guitar from falling on the floor, should I open the clamps without a good hold on the guitar. It has save me from a repair more than once. (I think that suggestion also came from the GAL article.)
* Let me jump on my soapbox for a second; I am a strong advocate of both the GAL and ASIA. Join em both. Lots of the wisdom in these forums came from the folks that took the time to publish their ideas or present their knowledge at one of the conventions. Don’t get me wrong … I love the guitar forums on the net, but lets keep those originations strong through our memberships.
PostPosted: Mon Jun 12, 2006 8:41 am
John, you've probably used your vise for a long time without incident, but those building one for the first time, I'd suggest some foam pipe insulation on the pipes between the jaws. That way you won't scratch or dent your guitar when it inevitably bumps a pipe. The foam is cheap and readily available in the plumbing section of your local hardware/home center.
PostPosted: Mon Jun 12, 2006 12:24 pm
Carlton
Yea I saw that foam in one of the photos above. That is a good idea. I am sure I got something around here, or I will pickup some of that insulation at the home center... An ounce of prevention.
