It is currently Tue Aug 12, 2025 1:54 am
PostPosted: Sun Jun 18, 2006 11:18 am
For the last two weeks I've been building cabinets for the shop, I found a design sometime ago in one of the wood magazine shop issues that allowed you to build cabinets with flip tops. In the issue they showed one where they had joined a performax with a flip top and gotten two tools out of one cabinet, Neat!!
So I bookmarked it in my collection and waited, well with the new shop being put together I took the plunge, and what you see is the result of their plans and some mods on my part.
This is the basic cabinet, the performax sits on a 3 drawer unit and is about 1/16" above the other cabinet, the trim wood is maple and the sides are MDO and MDF painted to match the shop. The cart has full locking wheels and is very easy to move, I decided that since I would be using the performax I would make this a sanding center:
Here's how you use the little sander, first you flip these little metal tabs:
Then you swing the sander over like this:
Now you swivel the tabs around to lock the top and close the door and your all set:
The beauty of this cabinet is that I get an extension for my performax and my little sander no longer needs to take up extra floor space, any jigs for the sander can go in the bottom of the fliptop and all the sandpaper and other items get stored in the drawers right where they are needed.
I added a little powerstrip to the unit so I could power everything from one plug (it also allows the cart to be mobile). I've actually built two of these, this one is for the sanders and the other is for the planer and jigsaw, but I'm thinking about making the flip top do dual duty on that one, one side for the scroll saw and the other for the binding cutter.
I liked the way these turned out so much that I'm building a much larger unit for the CNC using the same design as these, they are pretty simple to build and super strong when finished.
So if your looking for extra floor space, this could be a good option, I think the total for both cabinets was around $600 and that's with me doing a second set of flip tops because I didn't like the design of the first ones and made some changes.
-Paul-
-Paul-
Patriot Guitars
PostPosted: Sun Jun 18, 2006 12:39 pm
A good place to find these plans is www.woodmagazine.com. Paul, this is where you got the plans isn't it? I purchased the plans for the swivel topped cabinet, a smaller version of the one you built and hopefully will eventually get around to building it. These folks do have some good plans for benches, stands, and jigs so check em out.   Don A38886.9030787037
PostPosted: Sun Jun 18, 2006 1:50 pm
That's quite nifty, Paul.
PostPosted: Sun Jun 18, 2006 3:08 pm
Great idea.
PostPosted: Sun Jun 18, 2006 4:00 pm
Yep those are the ones Don, except mine came from a shop issue they published.
They are not hard to build really, you just need a good Dado Blade everything else is pretty standard. Like I said I took the basic design and have modified it for a table for my CNC, getting the flip top right took me two tries but the cabinets went together on the first try.
I'm thinking about converting over a number of my other little cabinets to these at some point...
-Paul-
-Paul-
Patriot Guitars
PostPosted: Mon Jun 19, 2006 1:09 pm
Great idea, one to save for future reference, thanks for sharing
Whit Oak, Texas
