It is currently Mon Aug 11, 2025 11:09 pm
PostPosted: Fri Jun 23, 2006 3:30 am
Anyone have fret bender plans or a suggetion for building a simple fret wire bender? I understand they can be made cheaply?
PostPosted: Fri Jun 23, 2006 4:39 am
First name: Martin
Last Name: Edwards
for my mandonaught I tried a new technique.
I put a slight bend on the frets by putting them in a 5mm hole drilled in a block of waste wood and .....
well.....
bending it!!!!
once that was done I used a T-bolt used to hold a vise onto the table of a vertical mill as a press in the pillar drill.
you can see the block with holes bottom left of the pic, with a few frets.......
I'm never gonna hammer frets again!!!martinedwards38891.5695833333
PostPosted: Fri Jun 23, 2006 5:20 am
First name: Mark
Last Name: Tripp
City: Olympia
State: Washington
Zip/Postal Code: 98506
LMI has fret bender plans
I built one, and it works pretty good, but I need to modify it a little for mando wire.
-Mark
Pullman, WA
trippguitars.com
OR
Find me on Facebook
PostPosted: Fri Jun 23, 2006 6:02 am
I have a piece of 2" wide by half circle, 14" radius piece of rock maple with a slot for the tang cut into it. It has a cam clamp on one end and I use a 1" hardwood dowel and burnish the wire to that 14" radius. This is real cheap. there is some spring back but is still close to 14" radius. Total cost is $3.00 for the clamp and the rest is scrap. I do loose about 1" per stick of wire as un usable but no big deal.MichaelP38891.6287037037
PostPosted: Fri Jun 23, 2006 7:41 pm
See this one on Kathy Matsushita's site.
Fret bender
When I buy my fret wire, it always comes in coils that mean it is already pre-bent, never had any trouble.
PostPosted: Sat Jun 24, 2006 3:42 am
If you buy your wire from LMI it comes coiled and doesn't have to be bent. I use a 16" radius and it works perfectly without bending.
