It is currently Wed Jul 23, 2025 10:51 pm
PostPosted: Sat Mar 19, 2005 2:51 pm
So we just strung up my son's guitar, and I ran into a problem I always seem to run into: As we add tension to the strings, the saddle tips forward at a slight angle. I can still adjust it in its angled-setting to proper intonation, but I hate the forward angle. Does anyone else have this problem, and how do you fix it? I was pretty careful to try to cut a slot that's the same thickness as the saddle, although I suppose there's always just a little wiggle room in there.
PostPosted: Sat Mar 19, 2005 5:19 pm
I just found this topic in an old AG mag. article by Frank Ford. From what he said, I don't think you want to risk the life of the bridge. Maybe you could make a new saddle to fit the slot.
DES - Farwell, MI
PostPosted: Sat Mar 19, 2005 11:38 pm
Kelby - there should be -NO- wiggle in the saddle slot, it should be a slight compression fit. I make mine so that Its possible but a little difficult to remove with your hand. Nice and snug --
PostPosted: Sun Mar 20, 2005 3:05 am
Thank you both for your responses. I may have overstated things when I said there was "wiggle room," but in light of the comment that it should be a little difficult to pull out by hand, I should probably make it a little tighter of a fit.
PostPosted: Sun Mar 20, 2005 3:33 am
I cut my saddle slot with about a 4 degree backward tilt. I have found that
with a slight tilt the strings actually pull the saddle up nice and straight
with no forward leaning at all. Works for me!
Sylvan
http://www.wellsguitars.com
