It is currently Tue Aug 12, 2025 8:09 am
PostPosted: Fri Jul 14, 2006 8:10 pm
First name: Martin
Last Name: Edwards
Hi gang,
I've been asked to build a 6/12 acoustic doubleneck.
Anyone ever done this or know where I could lay my paws on a pic of a bracing pattern other than the Ovation, cos I don't have a spare plastic bath to use as a back.........
Thanks in advance!!martinedwards38913.2162731482
PostPosted: Sat Jul 15, 2006 12:04 am
Been there done that ... here is mine, the X has 20 thou CF laminated in it, the bridge patch is likely a tad heavy at 3/16. I believe the X is sized at 10x18mm. The top is koa obviously, and was about .130 thick. i f I had to do it again (and I ahve been asked by more than one), I would make the neck block(s) one piece - it makes for an easier bend between the necks, as this one is actually two piece, both bent at about 50-60 thou, then epoxied together. You are also seeing a fairly heavy upper transverse, this allowed me to use all bolt on necks (see the thread on neck setting, you can see a neck that I used to use in there, same as for this guitar) It had to be 1/2 inch thick to allow for the mortice and small bolt to go into the FB extensions
PostPosted: Sat Jul 15, 2006 2:23 am
You got to love a guy who can switch between imperial and metric for building guitars.
Way to go Tony, your so Canadian.
Oh, awsome guitar as usual.
PostPosted: Sat Jul 15, 2006 4:06 am
yeah, weird huh .. some things I only know the measurement in metric, others imperial. Bridges, 6 inches long, saddle slot is 1/8 or 3/16 by 70mm, string spacing is 55 at the bridge, 1 3/4 at the nut !!! Sides 85 thou, backs 100-110 ..goes on and on. after all its just a number right. somethings are jsut easy to split if its metric. I use 25.4 scale, but cut all the slots in mm distances, set the intonation that way as well !!!
Lower bouts, thats in inches. Goofy stuff.
PostPosted: Sat Jul 15, 2006 5:14 am
First name: Martin
Last Name: Edwards
Thanks Tony, that looks great!!
How does having some strings not crossing the soundhole affect the sound? I was thinking about two soundholes with a "figure-of-eight" rosette, but a single would be easier.......
PostPosted: Sat Jul 15, 2006 2:17 pm
I dont know - should it make a difference ??? You are still exciting the top via string vibration - its not like the soundhole has to be under the strings.
PostPosted: Sat Jul 15, 2006 2:23 pm
Tony, you make me proud to be Canadian buddy!
Awesome work as usual!
PostPosted: Sat Jul 15, 2006 6:21 pm
Martin what a challenge!! You're gonna make it with great success; what woods will you use?
Of course there is the option of side upper bout sound ports..
This guitar has one soundhole, but notice it is larger and more oval A-LA Django Reinhardt
Sam Price38914.1407291667
PostPosted: Sun Jul 16, 2006 3:44 am
Tony, excellent design!
PostPosted: Sun Jul 16, 2006 4:40 am
Nice sofa cover Sam
PostPosted: Sun Jul 16, 2006 4:44 am
Personally, besides the excellent throw, is the heavy duty rocknroll selector switch on that baby !!!
