It is currently Wed Aug 13, 2025 3:01 am
Post new topic Reply to topic  [ 36 posts ]  Go to page Previous  1, 2
PostPosted: Mon Jul 17, 2006 9:23 am
I heard about it through Frank Ford and Jules Borges who have been very kind to share the info with myself and a lot of others. The basis has been covered by other, but did you know that Martin used to finish all the Koa guitars this way?
Warmest regards,
Terence
www.goodacoustics.com
www.et-al.blogspot.com
PostPosted: Mon Jul 17, 2006 10:21 am
I have given egg white a try during my quest for the ultimate pore filler . Yes , I found it dries as hard as , so watch for the surplus left isn't too great . Definatley put something with it for colour , as larger pores can turn white . It seems to need a few fills to get level.
I put it on Mahogany and didn't like the colour it changed it to . No, ,,,,,,, I hated the colour it went !
,,,,,,, Horrid !
Regards , KiwiKiwiCraig38915.8366782407
CRAIG LAWRENCE of AUSTRALIA
PostPosted: Mon Jul 17, 2006 10:52 am
Ever try to get egg off a car or a wall after it has hardened? Almost imposible. Very hard to do without damaging the paint. So I believe it would work as a filler.
PostPosted: Mon Jul 17, 2006 12:04 pm
a good sandblaster will get the area "around" the egg clean but it is as close to cement as possible...very stubborn.
PostPosted: Mon Jul 17, 2006 10:25 pm
Yeah, I dont use them on mahogany bodies or any of my necks.
I use a different method on the necks.
Man, i just learned how to make Shepherd pie, now do i have to follow an intensive cooking course to finish my guitars?
PostPosted: Tue Jul 18, 2006 2:59 am
Serge, you finish your guitars with Shepherd's Pie? or while eating it?
PostPosted: Tue Jul 18, 2006 5:15 am
Great idea, using the whites of an egg...
Is it compatible with Danish Oil?
PostPosted: Tue Jul 18, 2006 7:06 am
Shawn,
We should compare notes sometime...not many bass builders out here.
I am making a cornerless design now. It is based on old Italian shapes that I
have seen. Very sloping sholders for easy reach. Very deep ribs and wide
lower bout. I also built a violin shape with sloped sholders. You can see it
under custom instruments on my www.
PostPosted: Tue Jul 18, 2006 7:56 am
I know that Alan Carruth has built violin family instruments. I started by repairing violins before then building several. I have a good cello but could never afford a bass the quality (and age) I wanted so that is why I started to build them. I have only built 4 and those were for other musicians who also couldnt afford an early double bass.
It always amazes me the difference between the cost of a historic violin family instrument compared to the cost of even famous builders guitars.
I like the looks of the cornerless Italian instruments...they are different so they get peoples attention but also I like the proportions of the proportionally larger than expected lower bout.
I build classical and flamenco guitars exclusively but play alot of classical and chamber music so I manage to build a bit of everything.
PostPosted: Tue Jul 18, 2006 8:47 am
[QUOTE=peterm] Serge, you finish your guitars with Shepherd's Pie? or while eating it?
Peter, i was rather thinking peanut butter and jelly toasts, easier to cook and makes a lesser mess than Corn Flakes!
