It is currently Tue Aug 12, 2025 11:04 pm
PostPosted: Fri Jul 21, 2006 5:11 am
My last batch of hide glue is used up or thrown out so I have to make some more. What I have in mind is Frank Ford or Mario's method of cutting it up into small chunks but what I'd like to do is store them in the freezer till I need them which is only for stuff related to the top of my guitars. Is it OK to freeze hide glue or should it just be stored in the fridge. I'm thinking frozen glue may have a longer lifespan. Of the last batch I was only able to use about half before it went bad and it was a pretty small batch to start with.
TIA
PostPosted: Fri Jul 21, 2006 5:23 am
I have frozen mine for a long time and it worked fine. I double bagged it then put it in an air tight tupperware container.
PostPosted: Fri Jul 21, 2006 5:27 am
Hi John
It is fine to freeze hide glue, you just have to protect it from freezer burn, many guys freeze it in bottles, but if you put your cubes in freezer bags that should do the trick, I would Double bag them just to be sure. I've taken to making it fresh just lately, but it is of course a bit wasteful. I will keep it in the fridge for a working week but then I throw it out.
PostPosted: Fri Jul 21, 2006 5:29 am
Hesh
Colin uses the ice cube tray to form the cubes but he then keeps them in a jar in the fridge, and disposes of any after a week or so, I don't think he freezes it.
Fortunately I don't drink scotch. I'm a beer and brandy kinda guy.
Thanks Hesh & Brock & Russel, I really didn't think there was a problem freezing it. I just don't use enough so it goes bad even in the fridge.John How38919.6054861111
PostPosted: Fri Jul 21, 2006 8:28 am
John...I've used HHG that's been frozen in polyethylene bottles for as long as 9 months. Protect from freezer burn. I double bag the bottles.
PostPosted: Fri Jul 21, 2006 8:50 am
Thanks JJ. Hey you ever comin back to California?
PostPosted: Fri Jul 21, 2006 9:22 am
First name: Mark
Last Name: Tripp
City: Olympia
State: Washington
Zip/Postal Code: 98506
Same as Brock here - seems to work fine.
-Mark
Pullman, WA
trippguitars.com
OR
Find me on Facebook
