It is currently Sat Jul 26, 2025 10:14 am
PostPosted: Mon Apr 18, 2005 10:59 pm
do any of you guys put the frets in before gluing down the fretboard to the neck?   I think I saw a picture of ol what's his name who builds guitars and runs Grizzly fretting a fingerboard sans neck. He was pressing in the frets with a fret press and the fingerboard was riding on a little tray of some sort.
I like to press in frets but it is such a hassle from about the 9th fret on that I resort to the hammer.
If the fret board could be fretted before gluing then problems would be solved. (of course other problems would be generated)
PostPosted: Mon Apr 18, 2005 11:07 pm
I use to do it this way but found it very hard to get everything level after word - Now I glue down the board first - then the neck to the body - level everything up - and only then do I fret it - however this creates a very scary scenario of dealing with the frets over the body. I'm really interested in the semi-hemispherical fretting tech - since you almost completely finish the fret before it hits the neck, that takes a lot of risk out of it. I think Sylvan is doing a workshop on this - Wish I could make it -- hmm this gives me an idea - maybe its time for a guest speaker to do a live demo at the OLF-- SYLVAN!!!!!!!!!!!!!LanceK38461.3389467593
PostPosted: Tue Apr 19, 2005 12:46 am
I can't picture this not racking the fret-board no matter how the fret-board is sucured. Once you take it off it's carrier I would think it would warp like a big spring due to the tenion of the frets. I once installed 14-20 prior to gluing down the fretboard to the body. I had issues. I have not done it again.
PostPosted: Tue Apr 19, 2005 12:48 am
I use the taylor fret buck and don't worry about freting up over the body at all. I thought you had bought one of those do hickey's Lance. Try it you'll like it!
PostPosted: Tue Apr 19, 2005 4:33 am
[QUOTE=LanceK] I use to do it this way but found it very hard to get everything level after word - Now I glue down the board first - then the neck to the body - level everything up - and only then do I fret it - however this creates a very scary scenario of dealing with the frets over the body. I'm really interested in the semi-hemispherical fretting tech - since you almost completely finish the fret before it hits the neck, that takes a lot of risk out of it. I think Sylvan is doing a workshop on this - Wish I could make it -- hmm this gives me an idea - maybe its time for a guest speaker to do a live demo at the OLF-- SYLVAN!!!!!!!!!!!!![/QUOTE]
Yes!!! I very much like that idea... or PERHAPS.... a VIDEO.... (Hint Hint)
I have been interested in this topic for a while now.
PostPosted: Tue Apr 19, 2005 5:57 am
You guys have articulated what I suspected. The wedging effect of the fret tang curving that fretboard. I was thinking that if you were to have everything else really flat you could force the fretted board to conform. BUT, it is so easy to redo the fingerboard flattness after gluing to the neck (if the frets are not in) that I think it probably outweighs the other convenience
I will second (or third) the hemispherical fretting online tutorial. Great Idea
PostPosted: Tue Apr 19, 2005 6:01 am
I have tried going this rout too John as I thought it would be nice to do the fret work clear of the guitar but It's difficult to maintain the flatness while glueing.
PostPosted: Tue Apr 19, 2005 6:08 am
Seems unanymous. I guess I'll file that in the "bad Idea" dept and thank all of you for saving me the trouble of learning the hard way.
One advantage of having a bolt on fingerboard extension is that you can fret that extension without it being on the guitar and avoid at least that particular stress filled operation
PostPosted: Tue Apr 19, 2005 10:05 am
First name: Scott
Last Name: Thompson
Actually I do fret first up to the end of the neck -12th or 14th fret. I use a hammer, not a press. That is the way I did it on my first guitar and it worked for me so I haven't bothered changing. My first guitar was a Stew-Mac kit and that's how Dan Erlewine teaches it. You then give some back bow to the neck during glue up. If you want to see the tutorial, you can go to the stew-mac site, find the page for the steel string kits and download the instruction book.
Scott Thompson
Port Townsend,WA
-Billy Bragg
PostPosted: Tue Apr 19, 2005 12:19 pm
http://luthiersforum.3element.com/pages/jig_tools_tech/frett ing_by_tim_mcknight.htm
Lots of ways to skin a cat but the above method has worked well for me.
Someone asked how to protect the top? I use pieces of padded linoleum vinyl flooring cut to the shape of the top. It is durable enough to protect the finish from slips with a file and thin enough to still allow finishing the fret ends.
tim...
PostPosted: Tue Apr 19, 2005 12:23 pm
This was discussed recently on MIMF in a topic on hammering or pressing frets, and I was suprised how many people said that they did it ahead of time. I suppose if you can supply a lot of pressure evenly along the fretboard, there should be no problem. But that's a big if.
PostPosted: Tue Apr 19, 2005 12:30 pm
One downside to pre-fretting is IF your fingerboard isn't perfectly flat or you have a weird hump develop at the neck to body junction the only way to level is by filing frets [which isn't a good habbit to get into]. Personally I like to start with a dead flat FB, that is level sanded in the playing position and then add the frets. I don't have any problems with back bows due to post fret installation.
tim...
PostPosted: Tue Apr 19, 2005 1:12 pm
Bro I always thought your system was pretty good.
It was / is mine that's so bad.
PostPosted: Wed Apr 20, 2005 8:08 am
I've been using the fret press before installing the fretboard. I've never had a problem with bowing (knock on wood). I just checked 2 that have been on the shelf for a year and they are still dead flat. Don't some folks cut the slots larger over the body and glue in the frets?
PostPosted: Wed Apr 20, 2005 9:33 am
I take a small triangular shaped needle file and put a slight chamfer on the fret slot to guide the fret in while hammering them.
tim...
PostPosted: Wed Apr 20, 2005 10:31 am
In the semi-hemispherical fretting method all frets are cut to precise
length and the ends are rounded and polished with jeweler's rouge before
the frets are ever put in the fingerboard. They are so polished the frets
literally look like jewelry! There is absolutely no cleaning up the edges of
the frets since all of the frets fit very precisely. They are not "pressed" in
with an arbor press or banged in with a hammer. It is a very precise
method as each fret is actually about .010" in from the sides of the
fretboard so the player will not "feel" any fret end. The other real
advantage is that if the guitar goes to a low humidity enviroment and the
fretboard shrinks there is nothing to fix (sharp fret ends). It has also been
my experience that there is also very little leveling that has to be done
once the frets are in the board. When I do this method (which is the only
way I fret my guitars now) the neck and body are finished and joined. I
then level the fretboard and begin the fretting process. The method is not
difficult but it took me about a year to perfect the original Harry
Fleishmann technique in a way that is repeatable and easily learned.
Lance, what do you have in mind as to sharing the method other than a
demo and teaching at my seminar?
Sylvan
http://www.wellsguitars.com
PostPosted: Wed Apr 20, 2005 11:59 am
Sylvan:
Could you post some step by step pics or basic instructions from measuring, cutting, polishing and methodology of inserting the frets. Any pitfalls to watch out for along the way. Any hard lessons that you have learned that would save us grief and shorten the learning curve? Maybe put together a Word document and insert some pictures to correspond with your text. Just trying to throw out some food for thought. TIA for sharing!
tim...
PostPosted: Wed Apr 20, 2005 12:08 pm
Sylvan, How bout a new article on your website!!!
PostPosted: Wed Apr 20, 2005 12:38 pm
Hey guys. I'm getting in on this one a little late.
I'm bucking the system I guess. I've done it both ways and actually prefer to press them prior to attaching the board to the neck. I always get a slight bow it the board but it easily disappers when I put a caul on and clamp it onto the neck.
I once broke off a fretboard at the 14th fret when I was pressing a fret into the extension. I thought I had it supported well but I guess I was wrong. That experience made me rethink my system.
Call me crazy but I like doing it this way.
PostPosted: Wed Apr 20, 2005 2:24 pm
Sylvan... you *** could *** cobble together a video... then you could see if Stew Mac or LMI would be interested in carrying it. It might make it worth the effort.
I am sure if you shot the raw footage it wouldn't be too hard to find someone to edit it.
I learn a lot more from seeing someone do it, than reading about how it is done.
PostPosted: Wed Apr 20, 2005 10:26 pm
Sylvan - a video would be great- But for the short run -
if your interested in doing a group of pictures showing step by step that would great too. I'd love to add that to the jigs tools and techs section.
My Dad is very adept at video editing and might be interested in doing the editing on a video should you decide to do one - I could ask him?
I also like the idea of adding a video help feature to the OLF - this might be a great one to start with?
Lance
PostPosted: Thu Apr 21, 2005 12:06 am
Either way you go with this Sylvan, I think you would get a lot of interest in it.
PostPosted: Thu Apr 21, 2005 5:01 am
I have thought about everyone's suggestions and am not at all sure that
you could adequately explain the process with photos and written
instructions. So that's out. A video might be possible but I just do not
know if I want to do that right now. I have the seminar coming up and
people are paying for the information-I don't think it would be right to
publish it - certainly before the seminar. Maybe after ASIA's symposium I
might consider it. So, Lance, for now hold off talking with your father. I
really appreciate the offer but I just am not ready TODAY.
Sylvan
PostPosted: Thu Apr 21, 2005 5:48 am
OK - thanks Sylvan -
Completely understandable --
