It is currently Mon May 19, 2025 12:40 am
PostPosted: Wed Feb 14, 2007 4:50 am
I was wondering how long you fellas wait to string up a guitar after your bridge has been glued on?
PostPosted: Wed Feb 14, 2007 4:57 am
I wait at least 24 hours. Someone told me that was the correct amount of time but I can't remember who it was.
Oh yeah, I use HHG to glue my bridges on. Could be different with other glues.
PostPosted: Wed Feb 14, 2007 5:11 am
HHG...24 hours...no less just to be sure. Patience pays off here.
PostPosted: Wed Feb 14, 2007 5:52 am
24 hrs.
Long
PostPosted: Wed Feb 14, 2007 6:01 am
Depends on how much beer remains in the bottle. If it's full, could be 3 minutes...1/2 or less, probably no more than about 45 seconds.
PostPosted: Wed Feb 14, 2007 6:02 am
I wait 48 hours before putting any tension on the bridge, just to be safe.
PostPosted: Wed Feb 14, 2007 6:07 am
Yep, after all the hours, trial and tribulations of building a git-box, I like to wait at least 24 hrs. I also use HHG.
PostPosted: Wed Feb 14, 2007 6:41 am
First name: Josh
Last Name: French
City: Houston
I generally glue the bridge mid day or end of the day, and then string her up the next morning.
Once though, I glued a bridge on and strung the guitar after one hour and it was/is fine.
Usually I use the fish glue.
Instagram: @jfrenchluthier
PostPosted: Wed Feb 14, 2007 7:18 am
I use LMI white and give it a bit over 24 hours...
PostPosted: Wed Feb 14, 2007 8:03 am
First name: Larry
Last Name: Hawes
I used LMI white and rushed the clamping which I would guess at about 10 hours. Stung it up within another 4 and the bridge crept toward the nut overnight about 1/8".
Re-glued and left it clamped for 24 hours. Re0strung and no problems for a year now.
Thank You and Best To All
PostPosted: Wed Feb 14, 2007 10:12 am
yeah 24 hours too with AR glue. Not any failure yet!!
PostPosted: Wed Feb 14, 2007 12:21 pm
Thanks folks.
PostPosted: Wed Feb 14, 2007 10:21 pm
First name: Martin
Last Name: Edwards
At least overnight with PVA
Haven't lost one yet (6 and 0)
PostPosted: Fri Feb 16, 2007 5:36 am
I have strung up a guitar after about 3 hrs or so and it was fine, but I think the 24 hr wait time is the best way. I was in a hurry.
Blake
PostPosted: Fri Feb 16, 2007 7:46 am
[QUOTE=martinedwards] At least overnight with PVA
Haven't lost one yet (6 and 0)[/QUOTE]
Someone can correct me if Im wrong but isnt the shear strength of PVA glue not that good compared to AR and HHG?
PostPosted: Fri Feb 16, 2007 9:34 am
With my guitars I usually give it 24hrs before stringing up, I use HHG, but that is usually because I glue it up one evening, go to work, then string it up next evening.
On my lutes the gap is usuallly something like 2 or 3 months. That's because I glue on the bridge before gluing the top to the shell!
PostPosted: Sun Feb 18, 2007 8:42 am
[QUOTE=kiwigeo]Someone can correct me if Im wrong but isnt the shear strength of PVA glue not that good compared to AR and HHG?[/QUOTE]
Martin,
AR glue IS PVA glue, with some additives. I understand the name change was a marketing spin, to distinguish it from the Elmer's white we used in grade school. There are some premium whites, like the LMI stuff, that are as strong (maybe stronger) in shear as the yellow.
PostPosted: Sun Feb 18, 2007 10:41 am
Hi Carlton,
I realise that AR glue is modified PVA but I was led to believe that resistance to shear stress is better for AR than PVA. I havent used LMI's PVA so dont know much about it but I have found the commonly available PVAs (eg Selley's) here in Australia inferior to Titebond for bridge gluing.
PostPosted: Sun Feb 18, 2007 4:29 pm
Martin,
Nobody's talking, but perhaps the only white glue that's any good for lutherie is made by Franklin (the Titebond people), and distributed under other names. There was a thread here some time ago about a certain type of Franklin white, only sold in gallons, that seems to be worthy for lutherie.
As far as LMI's white, my limited experiments have shown it to dry harder than any other AR/PVA I've had my hands on. A dry blob of it wants to break rather than bend. To me, that would indicate less creeping and greater shear strength. I haven't even reached "dilettante," much less "expert," though, so YMMV.
PostPosted: Tue Feb 20, 2007 2:22 am
First name: Martin
Last Name: Edwards
I dunno folks, I just use the white stuff that I got from The DIY store.
really
