It is currently Thu Aug 21, 2025 6:19 am
Post new topic Reply to topic  [ 48 posts ]  Go to page Previous  1, 2
PostPosted: Wed Feb 21, 2007 2:43 pm
Yes Mattia, the article states they are LMI...
I'll check out Home depot for the inserts..Thanks for the lead Tony..I'm feeling a little better about the Butt joint after everyones input..Thanks
PostPosted: Wed Feb 21, 2007 2:56 pm
[QUOTE=Hesh1956] Beautiful Steve!! [/QUOTE]
Thanks, Hesh! Even if it does have some b/w/b in there?
Irwin, I use the "standard" (?) brass inserts, drive them in with a "T" handled driver (made just for this purpose), then flood the surrounding wood with CA.
I do not think it would be possible to remove the inserts. They are as firm--it seems--as if they had grown in the tree.
Good luck,
PostPosted: Wed Feb 21, 2007 10:39 pm
Bro
   I really do like that all koa guitar and the heel looks very delicate and well formed to me. Great work. I am interested in the kind of inserts you get from Home Depot that you drive with the T handle driver. What do they look like?
KBE
PostPosted: Thu Feb 22, 2007 12:40 am
Thanks Steve, If someone of your skill (awesome photo) and experience finds a butt joint not only acceptable but preferred, then you have made up my mind..thanks so much..I also find Colins work and photo above fascinating..this thread is a keeper for me!!
PostPosted: Thu Feb 22, 2007 4:08 am
I have used threaded inserts made for wood applications... but it does make sence tome to use he other ones as the article sugests...
Anyone knows where to get them?
PostPosted: Thu Feb 22, 2007 4:49 am
Last Name: Abercrombie
I think these may be the brass inserts Steve is referring to...
http://www.leevalley.com/hardware/page.aspx?c=1&p=44203&cat= 3,41306,41311
PostPosted: Thu Feb 22, 2007 4:59 am
"once they have been driven in by hand, using a long bolt in the drill press to keep them straight."
Can you explain a bit more or post a photo? I use the deep thread steel inserts from McFeeleys. They have a hex socket on the end that I drive with a T-handle Allen key. It is sometimes hard to keep them from cocking as they go in.
I've looked at the tapered zinc inserts and they didn't look trustworthy to me from an intuitive sense of how they would hold.
PostPosted: Thu Feb 22, 2007 5:32 am
John (A&K), yes, those are indeed the inserts.
I got mine first from a local hardware store, then from Woodworker's Supply. They have a slot for a screwdriver to fit in for installation purposes, but I've never been satisfied with that. I'm sorry I can't post a pic of my T-handled driver, but it is simplicity itself. The tip end is threaded 1/4-20, drives into the insert, "bottoms out" on the shoulder, then starts to drive the insert with a good bit more persuasion than a screwdriver.
(bro--I sent you a pic of this...post if you want.)
PostPosted: Thu Feb 22, 2007 5:36 am
[QUOTE=Irwin R]
I also find Colins work and photo above fascinating!
You and me both, Irwin!
Thanks for the kind words.
PostPosted: Thu Feb 22, 2007 8:56 am
Love to Howard, but the web site wont let me upload the pix right now, maybe later ...
PostPosted: Thu Feb 22, 2007 9:24 am
[QUOTE=Steve Kinnaird] [QUOTE=Irwin R]
Steve[/QUOTE]
Thanks guys, group hug! I find that the breadth and depth of knowledge on this forum is mind blowing, when you have guys like Howard and Kevin and Joshua (add any other names you want) passing on their experience, it raises the standards of us all. (Then we go and look at Howard's website and get depressed again!).
PostPosted: Thu Feb 22, 2007 9:34 am
In the meantime, I will try to describe ....
so you need to align and clamp the neck onto the drill press table such that the face of the heel is square to the drill bit, and hence the driver bolt. Drill the hole, dont move a thing, then replace the bit with the driveer bolt - mine is a 3 inch stainless bolt, fully threaded (all 1/4-20) to the hex nut end, then thread on 2 one inch long threaded rod connector couplings (1/4-20 of course) - one goes right up to the nut end tight, and this is chucked into the drill. Put the other coupling on, and then onto the end after it, the threaded insert, but not so far as to have the bolt sticking out. Now lower the press so that the insert is over the hole, and using a 7/16 wrench( the outer size of the coupling nuts), turn the lower coupling by hand, all the while with the other hand applying pressure with the drill press, drive the insert in - it works like a charm, straight in EVERY time - it has no choice. Then simply snap the lower coupling off the insert with the wrench ( while driving it in, they get pretty tight together), and turn the drill press belt bacjwards to unthread the bolt from the insert.
Darn I wish the upload was working ....
PostPosted: Thu Feb 22, 2007 9:56 am
I get it all, except when you back the lower coupling bolt off the insert at the end, how do you "snap" it away without backing out the insert? By applying pressure with the drill press while you turn the wrench?
Thanks a bunch. The use of the coupling nuts was the part I needed.
PostPosted: Thu Feb 22, 2007 10:01 am
Usually, Howard, the lower coupling nut will release from the insert without much downward pressure, just a quick backward snap of the coupling with the wrench - the insert is driven in pretty snug to help this. If needed you could always hold the press's belt from turning (mine is open somewhat up top, its a 50's Canadian Beaver !!!), thus the insert and bolt cant turn as well ... you just need to try it !!!!
PostPosted: Thu Feb 22, 2007 10:02 am
PostPosted: Thu Feb 22, 2007 10:13 am
That should have been coupling nut, not coupling bolt, above.
Hey, why don't we have edit anymore?
PostPosted: Thu Feb 22, 2007 10:28 am
First name: James
Last Name: Bolan
City: Nashville
State: Tennessee
Being a carpenter for 30 years,I would never stick my butt in a joint.Seriously though, anyone can butt 2 pieces of wood together.It takes skill to M&T or DT.Isn`t building a guitar about being a special type of craftsman?Just my opinion.
                               James W B
_________________________________
I cut it twice and it`s still too short?
James W Bolan
Nashville Tennessee
PostPosted: Thu Feb 22, 2007 11:29 am
Going back to what Howard said to me on a previous thread, its not about making something simpler, its about making it elegant - well, there is nothing really elegant about something you cant really see, or doesnt improve the overall playability or tone of a guitar. So whats the point in complicating matters for no gain ???
Stradavarious used a butt joint and a nail ...
PostPosted: Thu Feb 22, 2007 1:25 pm
On the other hand:
"In the elder days of Art,
    Builders wrought with greatest care
Each minute and unseen part;
    For the Gods see everywhere."
--Henry Wadsworth Longfellow
PostPosted: Thu Feb 22, 2007 3:23 pm
Gee thanks Howard ... ruined my day Off to luthing confessional to repent ....
PostPosted: Thu Feb 22, 2007 3:43 pm
Howard, don't forget Bruce Dickey's immortal words, which are something of a rejoinder to Longfellow:
"In these modern days of Craft,
   Builders must rethink the way
Every piece is done. And that
   Seen or not---the gods won't pay!"
Good for you, Bruce!
PostPosted: Thu Feb 22, 2007 6:20 pm
[QUOTE=James W B] Being a carpenter for 30 years,I would never stick my butt in a joint.Seriously though, anyone can butt 2 pieces of wood together.It takes skill to M&T or DT.Isn`t building a guitar about being a special type of craftsman?Just my opinion.
                                 James W B
I cut it twice and it`s still too short? [/QUOTE]
There's also the weight argument; a mortise and tenon joint requires a much larger, bulkier neck block than a butt-jointed neck.
PostPosted: Fri Feb 23, 2007 6:10 am
City: Lawrence
Zip/Postal Code: 66047
[QUOTE=Mattia Valente] There's also the weight argument; a mortise and tenon joint requires a much larger, bulkier neck block than a butt-jointed neck.[/QUOTE]
That got me to thinking. I might have to try a butt joint some time. Any time I can save weight I'm all for it, as long as it doesn't effect the sound or durability
