It is currently Thu Sep 18, 2025 11:23 pm
PostPosted: Mon May 21, 2007 2:39 pm
Todd, great tutorial and post. Many thanks!
PostPosted: Mon May 21, 2007 3:27 pm
Neat. You are a gambler Todd. I see you won the bet! Thanks for sharing.
PostPosted: Mon May 21, 2007 7:21 pm
Very fine tutorial. I like the use of the small tablesaw
blades also, whenever possible- keeping those tip speeds *down*! For myself, I'd remove the waste with a little ripsaw, because I detest the dust- requires hand support for the cut, though. YMMV..
PostPosted: Tue May 22, 2007 12:28 am
Nice technique. Much better than mine. I use a hand plane to get it close
and finish with my sanding radius dish
PostPosted: Tue May 22, 2007 2:28 am
Nice Todd!  Good pictures for showing the process.  It does, however, require "Attitude" and "Conviction" that you are comfortable with the tool.
PostPosted: Tue May 22, 2007 4:32 am
Thanks, Todd! I cringe whenever I have to put my whole hand on that side of the fence, but I like your method. Fast and accurate. Maybe I need to cobble up a jig.
PostPosted: Tue May 22, 2007 4:46 am
Great tutorial!
Many thanks!
Charliewood
PostPosted: Tue May 22, 2007 4:56 am
Great tutorial Todd! I will have to try that for sure!
PostPosted: Tue May 22, 2007 10:45 am
Great tutorial Todd.
Peace,Rich
PostPosted: Tue May 22, 2007 11:57 am
Looks good with one exception. I'd be a little concerned about the "rocker" factor that the body will want to make as passing through the saw. The back of the blade is trying to pull up the guitar and the front is trying to slam it down. Since this is not a flat piece of stock going through it's a pretty unstable cut. If I were you, I'm make a cradle teh the rib will sit in as it passes through.
I'm a safety fanatic on the table saw and this is a cut I'd think twice about making.
cron
