It is currently Sun Jul 27, 2025 3:29 am
PostPosted: Wed Jun 08, 2005 1:59 am
I am about to attempt to try my first backstrapping of a neck and I am using a "smiley face" volute. I was thinking of using 3 laminations of veneers that are approximately .03" each. Do you think that is too thin for each layer?
For those of you who do this on a regular basis, can you offer comments as to the thickness of your veneers or any problems you have encountered with this?
My plan is to shape the general upward swoop of the volute, glue down the veneers, then carve the volute to shape.
Again.... just looking for advice from those who have been there and fell into the holes before me....
Brock Poling38511.4598032407
PostPosted: Wed Jun 08, 2005 2:29 am
Not sure what you mean by Backstrapping, are you talking about a rear headplate? I do exactly that, shape the plane of the volute/headstock and bend my plate to match this curve. Glue it on and shape the whole thing into a volute.
John How38511.4802314815
PostPosted: Wed Jun 08, 2005 3:31 am
Brock. I normally do this with a really thin piece as well. 30 thou sounds
about right.. I can't remember what the thickness of my last one was, but
it was thin. I just glued it down after the curve had been put on the
headstock and then carved it.. just as you suggest.
PostPosted: Wed Jun 08, 2005 3:38 am
Brock,
I don't know if this will help, but try this link. There may be a little more info. than you're looking for (It includes some info. on neck scarfing).
http://caldwellguitars.com/html/neckbuild.htmlJimmy Caldwell38511.5432986111
Jimmy Caldwell
PostPosted: Wed Jun 08, 2005 6:10 am
State: ON
Jimmy
I really like your setup. Thanks for sharing.
josh
Josh House
Canadian Luthier Supply
http://www.houseguitars.com
PostPosted: Wed Jun 08, 2005 6:17 am
John, that inlay on the back of the headstock is a very nice touch. You do classy work dude!
PostPosted: Wed Jun 08, 2005 6:21 am
Dave, you can say that again...it caught my attention right away. Great idea!
PostPosted: Wed Jun 08, 2005 6:43 am
Yes, it is the rear headplate. Thanks for the tips.
PostPosted: Wed Jun 08, 2005 9:10 pm
Last Name: Johnson
State: CO.
Zip/Postal Code: 80224
What is the max thickness for steel-string head?
PostPosted: Thu Jun 09, 2005 12:11 am
Bob, it depends on the tuners you are using. I think 1/2" is a safe bet.
PostPosted: Thu Jun 09, 2005 12:18 am
I think 1/2" is a little thin for Waverly's. The posts really stick out of the top. What are the rest of you guys using with Waverly's?
PostPosted: Thu Jun 09, 2005 2:23 am
John...great looking work!
Jimmie...I really like your technique. Thanks for sharing!
PostPosted: Thu Jun 09, 2005 3:09 am
My finished thickness for a non slotted headstock is 9/16"
PostPosted: Thu Jun 09, 2005 3:30 am
Thanks guys for the nice comments.... I dig your set-up too jimmy. If I
did more than 3 or so a year then I'd get a set-up like that for sure....
