It is currently Fri Jul 18, 2025 1:59 am
 Post subject: Bridge patch thickness
PostPosted: Sun Mar 16, 2008 10:20 am
I am curious what thickness folks are using for the bridge patches.
Anyone care to share this information?
PostPosted: Sun Mar 16, 2008 11:35 am
Mines are anywhere between .090" to .110".
Alain Moisan
(Now building just for fun!)
PostPosted: Sun Mar 16, 2008 2:21 pm
.100" for me.
Laminated, .050 Brazilian, .050 maple.
Mark
PostPosted: Sun Mar 16, 2008 2:25 pm
.090" for sugar maple, between .090" and .075" for Braz.
Laurent Brondel
West Paris, Maine - USA
PostPosted: Sun Mar 16, 2008 3:04 pm
Blanchard wrote:
.100" for me.
Mark
If you don't mind... which cap are you putting up (ball end side)?
PostPosted: Sun Mar 16, 2008 6:27 pm
.090 here BRW or HRW
PostPosted: Sun Mar 16, 2008 9:04 pm
0.10 EIR for me
PostPosted: Sun Mar 16, 2008 9:44 pm
.100", Padauk.
PostPosted: Sun Mar 16, 2008 10:33 pm
Brock Poling wrote:
Blanchard wrote:
.100" for me.
Mark
Maple glues to the soundboard, Braz takes the wear from the ball ends.
Mark
PostPosted: Sun Mar 16, 2008 11:59 pm
3/32" for me. VG Rock Maple.
I'm going to try out Frank Fords suggestion of running the patch grain parallel with the top as soon as I get over to the lumber yard and find a tight grain vg piece that's 7" wide...
-C
Freeborn Guitars
and home of BeauGuard©
PostPosted: Mon Mar 17, 2008 6:40 am
Usually around 90-100 thou with maple and EIR. I went down to about 60 thou on the last one made out of rock-hard Makore. With the high silica count, I figured it should do fine...
PostPosted: Mon Mar 17, 2008 9:18 am
maple. .09
PostPosted: Tue Mar 18, 2008 1:56 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
Robbie;
Did you mean for nylon strung guitars ?
If so mine are usually tapered from -1.5mm at the centerline and tapered to .5mm at the ends.
length at laeast as long as my bridge -but sometimes 20mm past the bridge length.
I've made full top width ones but the tone was a bit brittle.
width -15-25mm depending on what top I'm using and the sound I'm after for that guitar
Mike Collins
PostPosted: Tue Mar 18, 2008 2:10 pm
Mike Collins wrote:
Robbie;
Mike,
I was actually referring to steel string bridge patches but thanks for the info on the classical patches. I do something similar on my classicals.
PostPosted: Tue Mar 18, 2008 7:12 pm
mulberry .09
Ken Franklin
clumsy yet persistent
PostPosted: Wed Mar 19, 2008 5:15 am
Osage at .08
