It is currently Fri Apr 25, 2025 5:14 am
PostPosted: Sun Nov 27, 2005 11:16 pm
I am not known for my inlay work, in fact this is my first attempt at filling a customers request to personalize one of my guitars.
This star of David was a fun first project. I may make another one as I got a lot better at cutting the angles as I went along.
PostPosted: Sun Nov 27, 2005 11:22 pm
Very nice Matt! Will it be going in ebony?
PostPosted: Sun Nov 27, 2005 11:38 pm
Matt, If you want to make your star a bit fancier, you might consider using an overlapped design. This seems to be a traditional form for the Star of David.
Mike Mahar38684.3215509259
PostPosted: Mon Nov 28, 2005 1:19 am
Thanks, no it will be inlayed into a redish colored brazilian headplate.
Mike, that one is definitly cooler than the one I did, and as I look at it, I think yours is one less cut per side than mine.
all I know is I am going cross eyed, I have a ton of respect for you inlay artist guys, it is very demanding work, and I feel like I am all thumbs.
Matt
PostPosted: Mon Nov 28, 2005 1:34 am
That turned out real nice Matt.I have a lot of respect for the pro inlay artists out there too! I've only done a few inlays myself. Excellant job!
PostPosted: Mon Nov 28, 2005 1:56 am
Nice! I know the more I try to do inlay work, the more I respect the guitars I see on this forum!
PostPosted: Mon Nov 28, 2005 2:52 am
Very neat work Matt. It's not so "incredibly" difficult after all is it? Careful planning & forethought applied to the design stage and patience applied to the cutting process will allow you to do pretty cool inlay - even without lots of experience. I'll bet your next one will be even more intricate.
In fact, I've found that the hardest inlay cutting to do well is following a straight line - like you did. The curvy stuff allows for a more forgiving (read looser or sloppier) approach that can be smoothed with needle files before being inlaid.
Skip
PostPosted: Mon Nov 28, 2005 3:50 am
Nice work Matt.
PostPosted: Mon Nov 28, 2005 9:22 am
Hi Matt. Hey, you've got to start somewhere, right? And that is not a bad start at all. It will make for a beautiful addition to your guitar. Let's see pics when you're done.
Craig
