It is currently Thu Aug 21, 2025 10:07 pm
PostPosted: Thu Apr 21, 2011 8:52 am
First name: Ron
Last Name: Y
I realized that I need to remove close to another millimeter after the soundhole was cut. Should I be cautious when further thicknessing after the sound hole has already been cut out? I still have the center circle cut-off that I can fit back in when re-thicknessing.
Ron M.
PostPosted: Thu Apr 21, 2011 9:40 am
First name: Tom
Last Name: West
State: Nova Scotia
Rosette installed....???
PostPosted: Thu Apr 21, 2011 11:46 am
On a drum sander go right ahead. You won;t cause any damage to the cut out soundhole area.
PostPosted: Thu Apr 21, 2011 2:34 pm
First name: Tom
Last Name: West
State: Nova Scotia
Ron: Suggest you sand the inside surface if you are removing .040".
Tom
PostPosted: Thu Apr 21, 2011 3:16 pm
First name: Ron
Last Name: Y
Hi Tom
yes, It's installed. Thanks
Hi John,
thanks for help.
PostPosted: Fri Apr 22, 2011 12:12 am
Make sure that you have enough wood under your rosette if you are only thicknessing the back.
Ken Franklin
clumsy yet persistent
Users browsing this forum: DennisK and 32 guests
